Works fine sometimes and other times just completely freezes
LpeX
Post by LpeX »
So this is a problem I've had over several versions, basically UMS runs along side on my normal computer (the specs of it are here:)
By the way the media device im streaming to through a wired connection using my Asus RT-AC68U is an LG TV: LG UB820V
So the normal procedure when i'm going to watch something using UMS through my TV is I turn my tv on and wait for it to find the ums usually doesn't take too long, then I'll go into something and and try to watch it using Mencoder (I'm only really ever using this when I'm watching anime because the TV can't handle subs too well) there are 2 ways usually it plays out, it will load for a few seconds then start playing perfectly or it will load for 30 seconds and when it finally shows the footage it will be freezing and sometimes no audio will even play, so basically when the latter happens I just restart both UMS and TV until it fixes which isn't always right after one restart, it's completely random how many restarts it will take.
The log is when the freezing is happening.
(217.31 KiB) Downloaded 256 times
LpeX
Re: Works fine sometimes and other times just completely freezes
Post by LpeX »
bump
The logs look okay, can you try adding the following line to LG-LA6200.conf?
LpeX
Post by LpeX »
SubJunk wrote:The logs look okay, can you try adding the following line to LG-LA6200.conf?
No luck sadly, the first time I started the video it was fine, but after a restart of the TV and Server it went back to freezing and having a hard time buffering everything.
Any more ideas?
LpeX
Post by LpeX »
bump
LpeX
Post by LpeX »
DOUBLE BUMP
