Windows 10 Upgrade
Windows 10 Upgrade
Since upgrading to Windows 10, I can no longer use UMS as the media server for my PS3. I`ve looked online for fixes, but to no avail. Any fix for this problem?
Re: Windows 10 Upgrade
Have you tried to Full uninstall and reinstall?
Do any devices get shown on your UMS front screen?
Can you ping the PS3 from your windows 10 device?
Does your Windows firewall allow the UMS out Default is port 5001
Post your logs.... As per the FAQ: viewtopic.php?f=9&t=556
Andy
Andy
I had the same problem.
Fixed it by restoring defaults in windows firewall. Restarting UMS and telling the firewall to allow access.
All good again
All good again
