Version 2.2.0 is released
Post by SubJunk » Tue Dec 11, 2012 5:28 pm
General:
This release adds A-Z subfolders, "clean install" option to installer, improves DTS support, improves seeking and transcoding stability, improves audio sync, improves multithreading, and much more!
Changes since 2.1.2:
  • General:
    • Added option that creates virtual A-Z subfolders in folders with a lot of files (the last option on the Navigation/Share Settings page)
    • Added option to the Windows installer to perform a "clean install", which removes all configuration files before installing
    • Design and usability improvements
    • Logging improvements
    • Fixed audio/subtitle priority defaults
    • "Definitely disable subtitles" is more reliable
    • Fixed FFmpeg Web Video streaming
    • Fixed DTS support in FFmpeg
    • Improved FFmpeg speed
    • Added support for creating thumbnails from TIFF and other formats
    • Fixed numerous smaller bugs
    • Made thumbnail generation and browsing faster
    • Don't show the text "{External Subtitles}" if the display name is "[No Encoding]" within the transcode folder
    • Added support for True Motion and convertfps to AviSynth/FFmpeg engine
    • Made multithreading more stable with AviSynth/FFmpeg engine
    • Fixed RTL subtitle support
    • Improved stability while seeking and transcoding
    • Fixed custom MEncoder settings at renderer level
    • Added a check to the Windows installer that prevents installation until UMS is closed
  • Languages:
    • Minor updates to all languages
    • More text is translatable
    • Updated Brazilian
    • Updated Czech
  • Renderers:
    • Support more Android players (thanks, ExSport!)
    • Improved support for Panasonic TVs (thanks, ExSport!)
  • External Components:
    • Updated MPlayer/MEncoder to SB45, which:
      • Fixed audio stuttering/repeating bug
      • Fixed alpha for ASS subtitles
      • Improves permissions handling on Windows
      • Removes incorrectly categorised fonts
    • Updated FFmpeg to SB4, which:
      • Improves audio sync when seeking
      • Supports more rare avi files
      • Improves support for demuxing DTS-HD
      • Fixes dozens of memory leaks
      • Improves audio sync for some AVI files using MP3 audio
      • Improves FPS detection
      • Improved sync for interlaced video
      • Allows mid-stream channel layout change for flac audio
      • Supports 24-bit flac encoding
      • Improves support for some CPU-optimisations
      • Fixed a lot of bugs with the implementation of h264
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
The PMS developers
glebb for building UMS for OS X
Raker13
Re: Version 2.2.0 is released
Post by Raker13 » Thu Dec 13, 2012 2:51 am
First, thank you for all the work you put into the program.
Oddly, I have a problem w/2.2.0. I took the option to do the clean install. Installed and starts OK. But, the program turns all my MKV's into MPEGs and there are no options inside the transcode folder. No mencoder, no avisynth, etc. Just the MPEG. My OPPO will not stream MPEGs without decoding. I have uninstalled and reinstalled. Same issue.
I uninstalled 2.2.0 and reinstalled 2.1.2. The MKV's are back and the engines back again. I do not understand why 2.2.0 changes my MKV's into MPEGS and why the engines do not appear in the transcode folder.
Thanks upfront for advice.
Post by SubJunk » Thu Dec 13, 2012 7:20 am
Hi Raker13, please create a thread in the support forum for it :)
S7eele
Post by S7eele » Thu Dec 13, 2012 4:31 pm
Busy, busy, busy. Thanks as always to the team, look forward to trying this one out. Looks like a lot of work went into it.
mrkrabs
Post by mrkrabs » Thu Dec 13, 2012 7:56 pm
this release seems to bring some cool improvements! waiting for the mac version :)
Post by SubJunk » Fri Dec 14, 2012 10:21 am
mrkrabs wrote:this release seems to bring some cool improvements! waiting for the mac version :)
Just added it, hope you like it :)
nonolk
Post by nonolk » Wed Dec 19, 2012 12:48 am
Hello Subjunk,
Great work, the custom Mencoder options are back, I was finaly able to update to Universal media server.
Thank you very much for your work.
Best regards,
Nonolk.
