Version 1.1.0 is released
Post by SubJunk » Sat Jun 09, 2012 2:39 pm
General:
Changes since 1.0.1:
  • General:
    • Made program restarts more reliable
    • Fixed bug that occurred when resetting cache
    • Made buffer display in megabytes instead of bytes
    • Updated MediaInfo to 0.7.58
    • Branding
    • Fixed overscan compensation bug on some renderers (thanks to tMH for reporting the bug!)
    • Improved OS X tray icon (thanks, glebb!)
    • Added workaround for folder depth limits
    • Use UMS_PROFILE instead of PMS_PROFILE
    • Added support for audio that is 48Hz/24Hz
    • Fixed settings folder permissions
  • Renderers:
    • Added Yamaha RX-V671 (thanks, adresd!)
    • Added LG Smart TV Upgrader (600ST)
    • Added OPPO BDP-83 (thanks, counsil!)
    • Added OPPO BDP-93 (thanks, counsil!)
    • Added Sony Bravia 5500 series image
    • Added Sony Bravia EX series image
    • Added Panasonic TV image
    • Improved D-Link DSM-510 image
    • Improved Sony Blu-ray Player image
    • Improved Xbox 360 image
    • Improved Philips Streamium support
    • Fixed support for Samsung 2012 TVs (thanks, trooperryan!)
    • Numerous small improvements
  • AviSynth True Motion (InterFrame):
    • Supports more video cards
    • Improved stability
    • Improved compatibility with AviSynth 2.6
  • Languages:
    • Made Status tab more consistent across languages
    • Removed outdated translations
  • Installer:
    • Option to install AviSynth 2.6 MT
    • Option to set custom memory limit
Upgrade Notes:
It is recommended to uninstall the older version before installing the new one.
Madoka
Re: Version 1.1.0 is released
Post by Madoka » Sat Jun 09, 2012 2:55 pm
I must have snagged it right when you put it up as this announcement was not up yet.
I see the the maximum transcode buffer limit has be reaised to 700. Is the default still 400 (I didn't delete my UMS.conf file)? Also, is there any advantage to raising it to the max?
Also, I don't know much about AviSynth, but am I correct that if I use that engine I also need codecs like ffdshow for subtitles?
Finally, now that the installer has options, would you consider an option to install just the renderer.conf files you use?
Thanks for a great program!
Post by SubJunk » Sat Jun 09, 2012 3:06 pm
Madoka wrote:I see the the maximum transcode buffer limit has be reaised to 700. Is the default still 400 (I didn't delete my UMS.conf file)? Also, is there any advantage to raising it to the max?
Yeah the default is still 400. The maximum was raised because of the new option to increase memory in the installer. There's no real benefit to raising it. I watch high quality 1080p videos and have never needed more than 400.
Madoka wrote:Also, I don't know much about AviSynth, but am I correct that if I use that engine I also need codecs like ffdshow for subtitles?
Yes, it uses your computer's codecs. I recommend K-Lite Mega Codec Pack. I should add a FAQ entry on it too.
Madoka wrote:Finally, now that the installer has options, would you consider an option to install just the renderer.conf files you use?
I don't think so since there is no advantage in having fewer renderer files. You could have a million and the program would still run as fast.
Madoka wrote:Thanks for a great program!
You're welcome, thanks :)
counsil
Post by counsil » Sat Jun 09, 2012 8:51 pm
Awesome build Subjunk. My Oppo 93 is showing up (and displaying the correct png picture on the main page) and being streamed to correctly. My PS3's and Denon AVR's are recognized as well. My Denon's show up as Streamium devices, but UMS streams music to them just fine. I only tested my Denon 4311 and FLAC files are being streamed without transcoding occurring on the PC which is cool/correct because the Denon can play FLAC files natively.
I will keep testing but everything looks good so far.
BTW, the last version of UMS threw exceptions when I tried to make changes (I was trying to check the box to check for updates). It was permissions related. With this version I am not running into that issue. Perhaps some things were cleaned up with the third install of UMS? Third time was the charm?! :)
I am attaching my debug log show you can see my Denon's. They are IPS .20 and .21. I am also seeing some more exceptions that may be of some help. I don't have a clue why they are there.
DEBUG 2012-06-09 01:21:53.326 [main] error dumping pid java.io.FileNotFoundException: pms.pid (Access is denied)
DEBUG 2012-06-09 01:21:53.498 [main] Java version: 1.7.0_04
DEBUG 2012-06-09 01:21:53.498 [main] Java vendor: Oracle Corporation
DEBUG 2012-06-09 01:21:53.498 [main] Java class path: update.jar;ums.jar
DEBUG 2012-06-09 01:21:53.498 [main] Operating system name: Windows 7
DEBUG 2012-06-09 01:21:53.498 [main] Operating system architecture: x86
DEBUG 2012-06-09 01:21:53.498 [main] Operating system version: 6.1
DEBUG 2012-06-09 01:21:53.888 [main] SUN 1.7: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
DEBUG 2012-06-09 01:21:53.903 [main] SunRsaSign 1.7: Sun RSA signature provider
DEBUG 2012-06-09 01:21:53.903 [main] SunEC 1.7: Sun Elliptic Curve provider (EC, ECDSA, ECDH)
DEBUG 2012-06-09 01:21:53.903 [main] SunJSSE 1.7: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
DEBUG 2012-06-09 01:21:53.903 [main] SunJCE 1.7: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
DEBUG 2012-06-09 01:21:53.903 [main] SunJGSS 1.7: Sun (Kerberos v5, SPNEGO)
DEBUG 2012-06-09 01:21:53.903 [main] SunSASL 1.7: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5, NTLM; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5, NTLM)
DEBUG 2012-06-09 01:21:53.903 [main] XMLDSig 1.0: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
DEBUG 2012-06-09 01:21:53.903 [main] SunPCSC 1.7: Sun PC/SC provider
DEBUG 2012-06-09 01:21:53.903 [main] SunMSCAPI 1.7: Sun's Microsoft Crypto API provider
DEBUG 2012-06-09 01:21:53.903 [main] Set parameter http.useragent = Jakarta Commons-HttpClient/3.1
DEBUG 2012-06-09 01:21:53.903 [main] Set parameter http.protocol.version = HTTP/1.1
DEBUG 2012-06-09 01:21:53.903 [main] Set parameter http.connection-manager.class = class org.apache.commons.httpclient.SimpleHttpConnectionManager
DEBUG 2012-06-09 01:21:53.903 [main] Set parameter http.protocol.cookie-policy = default
DEBUG 2012-06-09 01:21:53.903 [main] Set parameter http.protocol.element-charset = US-ASCII
DEBUG 2012-06-09 01:21:53.903 [main] Set parameter http.protocol.content-charset = ISO-8859-1
DEBUG 2012-06-09 01:21:53.903 [main] Set parameter http.method.retry-handler = [email protected]a4
DEBUG 2012-06-09 01:21:53.903 [main] Set parameter http.dateparser.patterns = [EEE, dd MMM yyyy HH:mm:ss zzz, EEEE, dd-MMM-yy HH:mm:ss zzz, EEE MMM d HH:mm:ss yyyy, EEE, dd-MMM-yyyy HH:mm:ss z, EEE, dd-MMM-yyyy HH-mm-ss z, EEE, dd MMM yy HH:mm:ss z, EEE dd-MMM-yyyy HH:mm:ss z, EEE dd MMM yyyy HH:mm:ss z, EEE dd-MMM-yyyy HH-mm-ss z, EEE dd-MMM-yy HH:mm:ss z, EEE dd MMM yy HH:mm:ss z, EEE,dd-MMM-yy HH:mm:ss z, EEE,dd-MMM-yyyy HH:mm:ss z, EEE, dd-MM-yyyy HH:mm:ss z]
DEBUG 2012-06-09 01:21:54.949 [pool-2-thread-1] Open connection to universal-media-server.googlecode.com:80
DEBUG 2012-06-09 01:21:55.027 [pool-2-thread-1] >> "GET /git/src/main/external-resources/update/update_3.properties?currentVersion=1.1.0&operatingSystem=windows&cacheBuster=0.8621845169768755 HTTP/1.1[\r][\n]"
DEBUG 2012-06-09 01:21:55.027 [pool-2-thread-1] Adding Host request header
DEBUG 2012-06-09 01:21:55.058 [pool-2-thread-1] >> "User-Agent: Jakarta Commons-HttpClient/3.1[\r][\n]"
DEBUG 2012-06-09 01:21:55.058 [pool-2-thread-1] >> "Host: universal-media-server.googlecode.com[\r][\n]"
DEBUG 2012-06-09 01:21:55.058 [pool-2-thread-1] >> "[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "HTTP/1.0 200 OK[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "ETag: "32323437356236376533363236653161346263326137363238346130356365376665306366303963/src/main/external-resources/update/update_3.properties"[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "Date: Sat, 09 Jun 2012 06:21:59 GMT[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "Cache-Control: public,max-age=60[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "Accept-Ranges: none[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "Content-Type: text/plain; charset=ISO-8859-1[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "X-Content-Type-Options: nosniff[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "Server: git_frontend[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "X-XSS-Protection: 1; mode=block[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "Connection: close[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "[\r][\n]"
WARN  2012-06-09 01:21:55.307 [pool-2-thread-1] Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] Buffering response body
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "LatestVersion="1.1.0"[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] << "DownloadUrl.windows="http://universal-media-server.googlecode.com/files/UMS-1.1.0.exe"[\r][\n]"
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] Should close connection in response to directive: close
DEBUG 2012-06-09 01:21:55.307 [pool-2-thread-1] Releasing connection back to connection manager.
INFO  2012-06-09 01:21:56.103 [main] Starting Universal Media Server 1.1.0
INFO  2012-06-09 01:21:56.119 [main] Based on PS3 Media Server (ps3mediaserver.org) by shagrath, copyright 2008-2012
INFO  2012-06-09 01:21:56.119 [main] http://www.universalmediaserver.com
INFO  2012-06-09 01:21:56.134 [main]
INFO  2012-06-09 01:21:56.134 [main] Build: 4e3acd40a (2012-06-09)
INFO  2012-06-09 01:21:56.134 [main] Java: 1.7.0_04-Oracle Corporation
INFO  2012-06-09 01:21:56.134 [main] OS: Windows 7 x86 6.1
INFO  2012-06-09 01:21:56.134 [main] Encoding: UTF-8
INFO  2012-06-09 01:21:56.134 [main] Memory: 742 MB
INFO  2012-06-09 01:21:56.134 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-06-09 01:21:56.165 [main] Temp folder: C:\Users\Doug\AppData\Local\Temp\ps3mediaserver
INFO  2012-06-09 01:21:56.165 [main] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2012-06-09 01:21:56.165 [main] debug.log: C:\Users\Doug\AppData\Local\Temp\\debug.log
INFO  2012-06-09 01:21:56.165 [main] Profile directory: C:\ProgramData\UMS
INFO  2012-06-09 01:21:56.165 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2012-06-09 01:21:56.165 [main] Profile status: rw
INFO  2012-06-09 01:21:56.165 [main] Profile name: P6720F
INFO  2012-06-09 01:21:56.165 [main] Loading MediaInfo library
INFO  2012-06-09 01:21:58.427 [main] Loaded MediaInfoLib - v0.7.58
INFO  2012-06-09 01:21:58.443 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO  2012-06-09 01:21:58.443 [main] Loading configuration file: AirPlayer.conf
DEBUG 2012-06-09 01:21:58.443 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/AirPlayer.conf
INFO  2012-06-09 01:21:58.521 [main] Loading configuration file: Android.conf
DEBUG 2012-06-09 01:21:58.521 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Android.conf
INFO  2012-06-09 01:21:58.537 [main] Loading configuration file: Bravia4500.conf
DEBUG 2012-06-09 01:21:58.537 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Bravia4500.conf
INFO  2012-06-09 01:21:58.537 [main] Loading configuration file: Bravia5500.conf
DEBUG 2012-06-09 01:21:58.537 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Bravia5500.conf
INFO  2012-06-09 01:21:58.552 [main] Loading configuration file: BraviaEX.conf
DEBUG 2012-06-09 01:21:58.552 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/BraviaEX.conf
INFO  2012-06-09 01:21:58.552 [main] Loading configuration file: DLinkDSM510.conf
DEBUG 2012-06-09 01:21:58.552 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/DLinkDSM510.conf
INFO  2012-06-09 01:21:58.568 [main] Loading configuration file: FreeboxHD.conf
DEBUG 2012-06-09 01:21:58.568 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/FreeboxHD.conf
INFO  2012-06-09 01:21:58.568 [main] Loading configuration file: FreecomMusicPal.conf
DEBUG 2012-06-09 01:21:58.568 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/FreecomMusicPal.conf
INFO  2012-06-09 01:21:58.568 [main] Loading configuration file: iPad-iPhone.conf
DEBUG 2012-06-09 01:21:58.568 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/iPad-iPhone.conf
INFO  2012-06-09 01:21:58.568 [main] Loading configuration file: Kuro.conf
DEBUG 2012-06-09 01:21:58.568 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Kuro.conf
INFO  2012-06-09 01:21:58.568 [main] Loading configuration file: LGST600.conf
DEBUG 2012-06-09 01:21:58.568 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/LGST600.conf
INFO  2012-06-09 01:21:58.583 [main] Loading configuration file: N900.conf
DEBUG 2012-06-09 01:21:58.583 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/N900.conf
INFO  2012-06-09 01:21:58.583 [main] Loading configuration file: OPPOBDP83.conf
DEBUG 2012-06-09 01:21:58.583 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/OPPOBDP83.conf
INFO  2012-06-09 01:21:58.583 [main] Loading configuration file: OPPOBDP93.conf
DEBUG 2012-06-09 01:21:58.583 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/OPPOBDP93.conf
INFO  2012-06-09 01:21:58.583 [main] Loading configuration file: Panasonic.conf
DEBUG 2012-06-09 01:21:58.583 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Panasonic.conf
INFO  2012-06-09 01:21:58.599 [main] Loading configuration file: Philips.conf
DEBUG 2012-06-09 01:21:58.599 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Philips.conf
INFO  2012-06-09 01:21:58.599 [main] Loading configuration file: PhilipsPFL.conf
DEBUG 2012-06-09 01:21:58.599 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PhilipsPFL.conf
INFO  2012-06-09 01:21:58.646 [main] Loading configuration file: PopcornHour.conf
DEBUG 2012-06-09 01:21:58.646 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PopcornHour.conf
INFO  2012-06-09 01:21:58.646 [main] Loading configuration file: PS3.conf
DEBUG 2012-06-09 01:21:58.646 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PS3.conf
INFO  2012-06-09 01:21:58.661 [main] Loading configuration file: Realtek.conf
DEBUG 2012-06-09 01:21:58.661 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Realtek.conf
INFO  2012-06-09 01:21:58.661 [main] Loading configuration file: SamsungAllShare.conf
DEBUG 2012-06-09 01:21:58.661 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SamsungAllShare.conf
INFO  2012-06-09 01:21:58.661 [main] Loading configuration file: SamsungWiseLink.conf
DEBUG 2012-06-09 01:21:58.661 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SamsungWiseLink.conf
INFO  2012-06-09 01:21:58.661 [main] Loading configuration file: Showtime3.conf
DEBUG 2012-06-09 01:21:58.661 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Showtime3.conf
INFO  2012-06-09 01:21:58.661 [main] Loading configuration file: SonyBluray.conf
DEBUG 2012-06-09 01:21:58.661 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SonyBluray.conf
INFO  2012-06-09 01:21:58.661 [main] Loading configuration file: Streamium.conf
DEBUG 2012-06-09 01:21:58.661 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Streamium.conf
INFO  2012-06-09 01:21:58.661 [main] Loading configuration file: WDTVLive.conf
DEBUG 2012-06-09 01:21:58.677 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/WDTVLive.conf
INFO  2012-06-09 01:21:58.677 [main] Loading configuration file: WMP.conf
DEBUG 2012-06-09 01:21:58.677 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/WMP.conf
INFO  2012-06-09 01:21:58.677 [main] Loading configuration file: XBMC.conf
DEBUG 2012-06-09 01:21:58.677 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/XBMC.conf
INFO  2012-06-09 01:21:58.677 [main] Loading configuration file: Xbox360.conf
DEBUG 2012-06-09 01:21:58.677 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Xbox360.conf
INFO  2012-06-09 01:21:58.677 [main] Loading configuration file: YamahaRXV671.conf
DEBUG 2012-06-09 01:21:58.677 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/YamahaRXV671.conf
INFO  2012-06-09 01:21:58.677 [main] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-06-09 01:21:58.677 [main] launching: win32/mplayer.exe
DEBUG 2012-06-09 01:22:02.983 [main] launching: win32/mplayer.exe
INFO  2012-06-09 01:22:03.108 [main] Done!
INFO  2012-06-09 01:22:03.311 [main] Found AviSynth plugins dir: C:\Program Files (x86)\AviSynth\plugins
INFO  2012-06-09 01:22:03.327 [main] VSFilter.dll is not in the AviSynth plugins directory. This can cause problems when trying to play subtitled videos with AviSynth
INFO  2012-06-09 01:22:03.327 [main] Found VideoLAN version 2.0.1 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-06-09 01:22:03.389 [main] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2012-06-09 01:22:03.420 [main] Found plugin: net.pms.movieinfo.MovieInfo
INFO  2012-06-09 01:22:03.452 [main] Found plugin: com.chocolatey.pmsencoder.Plugin
INFO  2012-06-09 01:22:03.467 [main] PMSEncoder: initializing PMSEncoder 1.6.0
DEBUG 2012-06-09 01:22:03.514 [main] Current directory is not writable.
INFO  2012-06-09 01:22:03.514 [main] PMSEncoder: log directory: C:\Users\Doug\AppData\Local\Temp\
INFO  2012-06-09 01:22:03.514 [main] PMSEncoder: loading built-in log4j config file: jar:file:/C:/Program%20Files%20(x86)/Universal%20Media%20Server/plugins/pmsencoder-1.6.0.jar!/log4j_default.xml
INFO  2012-06-09 01:22:04.996 [main] Registering transcoding engine: PMSEncoder
INFO  2012-06-09 01:22:04.996 [main] PMSEncoder: checking engine list: [mencoder, avsmencoder, tsmuxer, ffmpegaudio, mplayeraudio, tsmuxeraudio, vlcvideo, mencoderwebvideo, mplayervideodump, mplayerwebaudio, vlcaudio, ffmpegdvrmsremux, rawthumbs]
INFO  2012-06-09 01:22:04.996 [main] PMSEncoder: enabled engine: [pmsencoder, mencoder, avsmencoder, tsmuxer, ffmpegaudio, mplayeraudio, tsmuxeraudio, vlcvideo, mencoderwebvideo, mplayervideodump, mplayerwebaudio, vlcaudio, ffmpegdvrmsremux, rawthumbs]
INFO  2012-06-09 01:22:05.058 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2012-06-09 01:22:05.058 [main] Registering transcoding engine: FFmpeg Audio
INFO  2012-06-09 01:22:05.058 [main] Registering transcoding engine: MEncoder
INFO  2012-06-09 01:22:05.058 [main] Registering transcoding engine: AviSynth/MEncoder
INFO  2012-06-09 01:22:05.058 [main] Registering transcoding engine: MPlayer Audio
INFO  2012-06-09 01:22:05.058 [main] Registering transcoding engine: MEncoder Web
INFO  2012-06-09 01:22:05.058 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2012-06-09 01:22:05.058 [main] Registering transcoding engine: MPlayer Web
INFO  2012-06-09 01:22:05.058 [main] Registering transcoding engine: tsMuxeR
INFO  2012-06-09 01:22:05.058 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2012-06-09 01:22:05.121 [main] Found VLC version 2.0.1 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-06-09 01:22:05.121 [main] Registering transcoding engine: VLC Audio Streaming
INFO  2012-06-09 01:22:05.121 [main] Registering transcoding engine: VLC Video Streaming
INFO  2012-06-09 01:22:05.121 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2012-06-09 01:22:05.121 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2012-06-09 01:22:05.199 [main] Using address /192.168.75.36 found on network interface: name:eth4 (Generic Marvell Yukon 88E8053 based Ethernet Controller)
INFO  2012-06-09 01:22:05.199 [main] Created socket: /192.168.75.36:5001
INFO  2012-06-09 01:22:05.277 [main] Checking shared folder: Z:\My Movies\My Movies
INFO  2012-06-09 01:22:05.277 [main] Checking shared folder: Z:\My TV Shows\My TV Shows
INFO  2012-06-09 01:22:05.277 [main] Checking shared folder: C:\Backups\My Music\My Music
INFO  2012-06-09 01:22:05.277 [main] Checking shared folder: C:\Backups\My Pictures\My Pictures
INFO  2012-06-09 01:22:05.277 [main] Checking shared folder: C:\Backups\My Videos\My Videos
INFO  2012-06-09 01:22:05.277 [main] Checking shared folder: F:\Movie Backups\Movie Backups
INFO  2012-06-09 01:22:05.277 [main] Checking shared folder: K:\TV Show Backups\TV Show Backups
INFO  2012-06-09 01:22:05.277 [main] Checking shared folder: L:\TV Show Backups II\TV Show Backups II
DEBUG 2012-06-09 01:22:05.589 [main] Sending ALIVE...
INFO  2012-06-09 01:22:05.667 [main] Using the following UUID configured in UMS.conf: a6b05349-81d8-4b4a-9500-8ff315596360
INFO  2012-06-09 01:22:08.352 [New I/O server worker #1-1] No IP filter specified, access granted to /192.168.75.29
INFO  2012-06-09 01:22:08.435 [New I/O server worker #1-1] Another renderer like Samsung AllShare was found!
INFO  2012-06-09 01:22:08.437 [pool-7-thread-1] Checking IP: 192.168.75.29 for Samsung AllShare
INFO  2012-06-09 01:22:08.637 [New I/O server worker #1-3] No IP filter specified, access granted to /192.168.75.36
INFO  2012-06-09 01:22:08.639 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Mozilla/4.0 (Compatible, Aggregation, Twonky, 7.0.7 )
INFO  2012-06-09 01:22:09.447 [New I/O server worker #1-4] No IP filter specified, access granted to /192.168.75.20
INFO  2012-06-09 01:22:09.449 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Mozilla/4.0 (compatible)
INFO  2012-06-09 01:22:10.218 [New I/O server worker #1-6] No IP filter specified, access granted to /192.168.75.21
INFO  2012-06-09 01:22:10.218 [New I/O server worker #1-6] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Mozilla/4.0 (compatible)
INFO  2012-06-09 01:22:10.342 [main] The server should now appear on your renderer
INFO  2012-06-09 01:22:11.450 [New I/O server worker #1-8] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Mozilla/4.0 (Compatible, Aggregation, Twonky, 7.0.7 )
INFO  2012-06-09 01:22:11.824 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Mozilla/4.0 (Compatible, Aggregation, Twonky, 7.0.7 ), X-RequestExtraMetadata: true
INFO  2012-06-09 01:22:11.871 [pool-7-thread-2] Checking IP: 192.168.75.20 for Streamium
INFO  2012-06-09 01:22:12.573 [New I/O server worker #1-4] Another renderer like Streamium was found!
INFO  2012-06-09 01:22:12.573 [pool-7-thread-3] Checking IP: 192.168.75.21 for Streamium
INFO  2012-06-09 01:22:13.478 [pool-7-thread-1] Renderer Samsung AllShare found on this address: 192.168.75.29
DEBUG 2012-06-09 01:22:13.728 [pool-7-thread-1] Starting ping -n 3 -l 64000 192.168.75.29
DEBUG 2012-06-09 01:22:15.740 [SpeedStats Failsafe] Stopping process: ping-0
INFO  2012-06-09 01:22:15.740 [pool-7-thread-1] Address /192.168.75.29 has an estimated network speed of: 85 Mb/s
INFO  2012-06-09 01:22:16.941 [pool-7-thread-2] Renderer Streamium found on this address: 192.168.75.20
DEBUG 2012-06-09 01:22:16.941 [pool-7-thread-2] Starting ping -n 3 -l 64000 192.168.75.20
INFO  2012-06-09 01:22:17.628 [pool-7-thread-3] Renderer Streamium found on this address: 192.168.75.21
DEBUG 2012-06-09 01:22:17.628 [pool-7-thread-3] Starting ping -n 3 -l 64000 192.168.75.21
DEBUG 2012-06-09 01:22:18.954 [SpeedStats Failsafe] Stopping process: ping-1
DEBUG 2012-06-09 01:22:19.640 [SpeedStats Failsafe] Stopping process: ping-2
DEBUG 2012-06-09 01:22:20.358 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:22:45.626 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:25:49.099 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:28:54.244 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:31:58.263 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:35:03.204 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:37:11.319 [New I/O server worker #1-7] Caught exception
	at net.pms.network.RequestV2.answer(RequestV2.java:700) ~[ums.jar:na]
	at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:313) ~[ums.jar:na]
	at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:271) ~[ums.jar:na]
	at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:148) ~[ums.jar:na]
	at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:116) ~[ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) ~[ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.unfoldAndfireMessageReceived(ReplayingDecoder.java:522) ~[ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:506) ~[ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:443) ~[ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) ~[ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) ~[ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:349) ~[ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:280) ~[ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:200) ~[ums.jar:na]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_04]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_04]
	at java.lang.Thread.run(Unknown Source) [na:1.7.0_04]
DEBUG 2012-06-09 01:38:06.731 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:41:12.154 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:44:16.554 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:44:39.562 [New I/O server worker #1-1] Caught exception
DEBUG 2012-06-09 01:44:40.451 [New I/O server worker #1-2] Caught exception
DEBUG 2012-06-09 01:47:21.085 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:50:26.376 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:53:12.350 [New I/O server worker #1-3] Caught exception
DEBUG 2012-06-09 01:53:32.022 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:56:35.839 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 01:59:42.202 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:02:47.763 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:05:53.661 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:08:12.951 [New I/O server worker #1-5] Caught exception
DEBUG 2012-06-09 02:08:58.206 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:12:01.877 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:15:07.366 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:18:11.885 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:21:16.400 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:23:15.572 [New I/O server worker #1-7] Caught exception
DEBUG 2012-06-09 02:24:22.434 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:27:27.505 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:30:31.751 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:33:36.062 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:36:42.398 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:39:46.077 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:40:44.356 [New I/O server worker #1-1] Caught exception
DEBUG 2012-06-09 02:42:51.964 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:45:55.071 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:48:59.143 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:52:03.223 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:55:07.570 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 02:55:45.016 [New I/O server worker #1-3] Caught exception
DEBUG 2012-06-09 02:58:14.074 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 03:01:19.025 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 03:04:22.471 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 03:07:28.349 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 03:10:34.201 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 03:10:46.468 [New I/O server worker #1-5] Caught exception
DEBUG 2012-06-09 03:13:39.101 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 03:16:43.663 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 03:19:49.023 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 03:22:53.812 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 03:26:00.056 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 03:28:14.657 [New I/O server worker #1-7] Caught exception
DEBUG 2012-06-09 03:29:04.343 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 03:32:09.636 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2012-06-09 03:32:43.040 [New I/O server worker #1-1] Checking shared folder: Z:\My Movies\My Movies
INFO  2012-06-09 03:32:43.040 [New I/O server worker #1-1] Checking shared folder: Z:\My TV Shows\My TV Shows
INFO  2012-06-09 03:32:43.040 [New I/O server worker #1-1] Checking shared folder: C:\Backups\My Music\My Music
INFO  2012-06-09 03:32:43.040 [New I/O server worker #1-1] Checking shared folder: C:\Backups\My Pictures\My Pictures
INFO  2012-06-09 03:32:43.040 [New I/O server worker #1-1] Checking shared folder: C:\Backups\My Videos\My Videos
INFO  2012-06-09 03:32:43.040 [New I/O server worker #1-1] Checking shared folder: F:\Movie Backups\Movie Backups
INFO  2012-06-09 03:32:43.040 [New I/O server worker #1-1] Checking shared folder: K:\TV Show Backups\TV Show Backups
INFO  2012-06-09 03:32:43.040 [New I/O server worker #1-1] Checking shared folder: L:\TV Show Backups II\TV Show Backups II
INFO  2012-06-09 03:33:33.210 [StartPlaying Event] renderer: 192.168.75.21, file: C:\Backups\My Music\My Music\000_Flac\Birdman\Priceless\05-Priceless (feat. Lil Wayne).flac
INFO  2012-06-09 03:34:02.772 [StartPlaying Event] renderer: 192.168.75.21, file: C:\Backups\My Music\My Music\000_Flac\Birdman\Priceless\11-Mo Milly (feat. Drake & Bun B).flac
INFO  2012-06-09 03:34:06.672 [StopPlaying Event] renderer: 192.168.75.21, file: C:\Backups\My Music\My Music\000_Flac\Birdman\Priceless\05-Priceless (feat. Lil Wayne).flac
DEBUG 2012-06-09 03:35:14.142 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2012-06-09 03:38:06.160 [StopPlaying Event] renderer: 192.168.75.21, file: C:\Backups\My Music\My Music\000_Flac\Birdman\Priceless\11-Mo Milly (feat. Drake & Bun B).flac
INFO  2012-06-09 03:38:15.161 [StartPlaying Event] renderer: 192.168.75.21, file: C:\Backups\My Music\My Music\000_Flac\Birdman\Priceless\12-I Want It All (feat. Lil Wayne & Kevin Rudolf).flac
DEBUG 2012-06-09 03:38:19.654 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2012-06-09 03:41:24.270 [StopPlaying Event] renderer: 192.168.75.21, file: C:\Backups\My Music\My Music\000_Flac\Birdman\Priceless\12-I Want It All (feat. Lil Wayne & Kevin Rudolf).flac
DEBUG 2012-06-09 03:41:24.925 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2012-06-09 03:41:32.165 [StartPlaying Event] renderer: 192.168.75.21, file: C:\Backups\My Music\My Music\000_Flac\Birdman\Priceless\13-Always Strapped (Remix)(feat. Lil Wayne & Mackmaine).flac
Post by SubJunk » Sun Jun 10, 2012 1:34 am
counsil wrote:Awesome build Subjunk. My Oppo 93 is showing up (and displaying the correct png picture on the main page) and being streamed to correctly. My PS3's and Denon AVR's are recognized as well. My Denon's show up as Streamium devices, but UMS streams music to them just fine. I only tested my Denon 4311 and FLAC files are being streamed without transcoding occurring on the PC which is cool/correct because the Denon can play FLAC files natively.
Awesome! Thanks for the feedback :)
counsil wrote:BTW, the last version of UMS threw exceptions when I tried to make changes (I was trying to check the box to check for updates). It was permissions related. With this version I am not running into that issue. Perhaps some things were cleaned up with the third install of UMS? Third time was the charm?! :)
Yeah it was fixed, it's in the changelog at the bottom of the General section :)
counsil wrote:I am attaching my debug log show you can see my Denon's. They are IPS .20 and .21. I am also seeing some more exceptions that may be of some help. I don't have a clue why they are there.
Great, this will help a lot. I'll have a look at that tomorrow :)
shelftalker
Post by shelftalker » Sun Jun 10, 2012 4:42 am
To unexpirienced users:
There is a Mac build https://www.dropbox.com/s/9c9ip3ms1jsafwx/ums-1.1.0.dmg
I have not changed anything, just compiled. You can do it yourself in your terminal:
git clone https://code.google.com/p/universal-media-server/ && cd universal-media-server && mvn com.savage7.maven.plugins:maven-external-dependency-plugin:resolve-external && mvn com.savage7.maven.plugins:maven-external-dependency-plugin:install-external && mvn package
Post by SubJunk » Sun Jun 10, 2012 11:34 am
Thanks to glebb and shelftalker we have our first OS X release, grab it from the front page :) Cheers guys :)
