XBox 360 only sees UMS installed on other wireless devices.
I have always used UMS installed on my Desktop computer, which is wired into my network, however recently, my XBox 360 (connected wirelessly as it has always been) stopped seeing the UMS installed on my desktop(or any other computer wired into the router) and only sees it on other wirelessly connected devices (in this case, my laptop).
Has anyone run into this before? If so, have you managed to find a solution?
I don't know if they'll help but here's the start-up log from UMS on my Desktop...
and on my laptop...
Any help would be greatly appreciated.
12-18 14:28:23 Starting Universal Media Server 2.2.0
12-18 14:28:23 Based on PS3 Media Server by shagrath, copyright 2008-2012
12-18 14:28:23 http://www.universalmediaserver.com
12-18 14:28:23
12-18 14:28:23 Build: dad63b8b4 (2012-12-11)
12-18 14:28:23 Java: 1.7.0_09-Oracle Corporation
12-18 14:28:23 OS: Windows XP 64-bit 5.1
12-18 14:28:23 Encoding: UTF-8
12-18 14:28:23 Memory: 742 MB
12-18 14:28:23
12-18 14:28:23 Working directory: C:\Universal Media Server
12-18 14:28:23 Temp directory: C:\Users\Kyouju\AppData\Local\Temp\universalmediaserver
12-18 14:28:23 Logging config file: C:\Universal Media Server\logback.xml
12-18 14:28:23 debug.log: C:\Universal Media Server\debug.log
12-18 14:28:23
12-18 14:28:23 Profile directory: C:\ProgramData\UMS
12-18 14:28:23 Profile path: C:\ProgramData\UMS\UMS.conf
12-18 14:28:23 Profile permissions: rw
12-18 14:28:23 Profile name: Kyouju-PC
12-18 14:28:23
12-18 14:28:23 Loading MediaInfo library
12-18 14:28:24 Loaded MediaInfoLib - v0.7.61
12-18 14:28:24 Loading renderer configurations from C:\Universal Media Server\renderers
12-18 14:28:24 Loading configuration file: AirPlayer.conf
12-18 14:28:24 Loading configuration file: Android.conf
12-18 14:28:24 Loading configuration file: Bravia4500.conf
12-18 14:28:24 Loading configuration file: Bravia5500.conf
12-18 14:28:24 Loading configuration file: BraviaEX.conf
12-18 14:28:24 Loading configuration file: BraviaEX620.conf
12-18 14:28:24 Loading configuration file: DirecTVHR.conf
12-18 14:28:24 Loading configuration file: DLinkDSM510.conf
12-18 14:28:24 Loading configuration file: FreeboxHD.conf
12-18 14:28:24 Loading configuration file: FreecomMusicPal.conf
12-18 14:28:24 Loading configuration file: iPad-iPhone.conf
12-18 14:28:24 Loading configuration file: Kuro.conf
12-18 14:28:24 Loading configuration file: LGST600.conf
12-18 14:28:24 Loading configuration file: N900.conf
12-18 14:28:24 Loading configuration file: OPPOBDP83.conf
12-18 14:28:24 Loading configuration file: OPPOBDP93.conf
12-18 14:28:24 Loading configuration file: Panasonic.conf
12-18 14:28:24 Loading configuration file: Philips.conf
12-18 14:28:24 Loading configuration file: PhilipsPFL.conf
12-18 14:28:24 Loading configuration file: PopcornHour.conf
12-18 14:28:24 Loading configuration file: PS3.conf
12-18 14:28:24 Loading configuration file: Realtek.conf
12-18 14:28:24 Loading configuration file: Samsung-SMT-G7400.conf
12-18 14:28:24 Loading configuration file: SamsungAllShare.conf
12-18 14:28:24 Loading configuration file: SamsungWiseLink.conf
12-18 14:28:24 Loading configuration file: Showtime3.conf
12-18 14:28:24 Loading configuration file: SMP-N100.conf
12-18 14:28:24 Loading configuration file: SonyBluray.conf
12-18 14:28:24 Loading configuration file: SonyBraviaHX800.conf
12-18 14:28:24 Loading configuration file: Streamium.conf
12-18 14:28:24 Loading configuration file: WDTVLive.conf
12-18 14:28:24 Loading configuration file: WMP.conf
12-18 14:28:24 Loading configuration file: XBMC.conf
12-18 14:28:24 Loading configuration file: XBOX360.conf
12-18 14:28:24 Loading configuration file: YamahaRXA1010.conf
12-18 14:28:24 Loading configuration file: YamahaRXV671.conf
12-18 14:28:24 Please wait while we check the MPlayer font cache, this can take a minute or so.
12-18 14:28:24 Finished checking the MPlayer font cache.
12-18 14:28:24 Found VideoLAN version 2.0.3 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
12-18 14:28:24 Searching for plugins in C:\Universal Media Server\plugins
12-18 14:28:24 No plugins found
12-18 14:28:24 Registering transcoding engine: AviSynth/FFmpeg
12-18 14:28:24 Registering transcoding engine: FFmpeg Audio
12-18 14:28:24 Registering transcoding engine: MEncoder
12-18 14:28:24 Registering transcoding engine: AviSynth/MEncoder
12-18 14:28:24 Registering transcoding engine: MPlayer Audio
12-18 14:28:24 Registering transcoding engine: FFmpeg Web Video
12-18 14:28:24 Registering transcoding engine: MEncoder Web
12-18 14:28:24 Registering transcoding engine: MPlayer Video Dump
12-18 14:28:24 Registering transcoding engine: MPlayer Web
12-18 14:28:24 Registering transcoding engine: tsMuxeR
12-18 14:28:24 Registering transcoding engine: Audio High Fidelity
12-18 14:28:24 Registering transcoding engine: VLC Audio Streaming
12-18 14:28:24 Registering transcoding engine: VLC Video Streaming
12-18 14:28:24 Registering transcoding engine: FFmpeg DVR-MS Remux
12-18 14:28:24 Registering transcoding engine: dcraw Thumbnailer
12-18 14:28:24 Using address /192.168.1.3 found on network interface: name:eth3 (Realtek PCIe GBE Family Controller)
12-18 14:28:24 Created socket: /192.168.1.3:5001
12-18 14:28:24 Using database located at: C:\Universal Media Server\database
12-18 14:28:24 A tiny cache admin interface is available at: http://192.168.1.3:5001/console/home
12-18 14:28:24 Checking shared folder: C:\Users\Kyouju\Documents\Downloads
12-18 14:28:24 Checking shared folder: C:\Users\Kyouju\Downloads
12-18 14:28:24 Checking shared folder: E:\
12-18 14:28:24 Checking shared folder: F:\
12-18 14:28:24 Checking shared folder: G:\
12-18 14:28:24 Checking shared folder: H:\
12-18 14:28:24 Checking shared folder: I:\
12-18 14:28:25 Using the following UUID configured in UMS.conf: 4525a05e-2355-37c3-bdf5-78d22c5a0764
12-18 14:28:28 The server is now available for renderers to find
12-18 14:09:58 Starting Universal Media Server 2.2.0
12-18 14:09:58 Based on PS3 Media Server by shagrath, copyright 2008-2012
12-18 14:09:58 http://www.universalmediaserver.com
12-18 14:09:58
12-18 14:09:58 Build: dad63b8b4 (2012-12-11)
12-18 14:09:58 Java: 1.7.0_07-Oracle Corporation
12-18 14:09:58 OS: Windows Vista 32-bit 6.0
12-18 14:09:58 Encoding: UTF-8
12-18 14:09:58 Memory: 742 MB
12-18 14:09:58
12-18 14:09:58 Working directory: C:\Program Files\Universal Media Server
12-18 14:09:58 Temp directory: C:\Users\Kyouju\AppData\Local\Temp\universalmediaserver
12-18 14:09:58 Logging config file: C:\Program Files\Universal Media Server\logback.xml
12-18 14:09:58 debug.log: C:\Program Files\Universal Media Server\debug.log
12-18 14:09:58
12-18 14:09:58 Profile directory: C:\ProgramData\UMS
12-18 14:09:58 Profile path: C:\ProgramData\UMS\UMS.conf
12-18 14:09:58 Profile permissions: rw
12-18 14:09:58 Profile name: KyoujuMobile-PC
12-18 14:09:58
12-18 14:09:59 Loading MediaInfo library
12-18 14:10:01 Loaded MediaInfoLib - v0.7.61
12-18 14:10:01 Loading renderer configurations from C:\Program Files\Universal Media Server\renderers
12-18 14:10:01 Loading configuration file: AirPlayer.conf
12-18 14:10:01 Loading configuration file: Android.conf
12-18 14:10:01 Loading configuration file: Bravia4500.conf
12-18 14:10:01 Loading configuration file: Bravia5500.conf
12-18 14:10:01 Loading configuration file: BraviaEX.conf
12-18 14:10:01 Loading configuration file: BraviaEX620.conf
12-18 14:10:01 Loading configuration file: DirecTVHR.conf
12-18 14:10:01 Loading configuration file: DLinkDSM510.conf
12-18 14:10:01 Loading configuration file: FreeboxHD.conf
12-18 14:10:01 Loading configuration file: FreecomMusicPal.conf
12-18 14:10:01 Loading configuration file: iPad-iPhone.conf
12-18 14:10:01 Loading configuration file: Kuro.conf
12-18 14:10:01 Loading configuration file: LGST600.conf
12-18 14:10:02 Loading configuration file: N900.conf
12-18 14:10:02 Loading configuration file: OPPOBDP83.conf
12-18 14:10:02 Loading configuration file: OPPOBDP93.conf
12-18 14:10:02 Loading configuration file: Panasonic.conf
12-18 14:10:02 Loading configuration file: Philips.conf
12-18 14:10:02 Loading configuration file: PhilipsPFL.conf
12-18 14:10:02 Loading configuration file: PopcornHour.conf
12-18 14:10:02 Loading configuration file: PS3.conf
12-18 14:10:02 Loading configuration file: Realtek.conf
12-18 14:10:02 Loading configuration file: Samsung-SMT-G7400.conf
12-18 14:10:02 Loading configuration file: SamsungAllShare.conf
12-18 14:10:02 Loading configuration file: SamsungWiseLink.conf
12-18 14:10:02 Loading configuration file: Showtime3.conf
12-18 14:10:02 Loading configuration file: SMP-N100.conf
12-18 14:10:02 Loading configuration file: SonyBluray.conf
12-18 14:10:02 Loading configuration file: SonyBraviaHX800.conf
12-18 14:10:02 Loading configuration file: Streamium.conf
12-18 14:10:02 Loading configuration file: WDTVLive.conf
12-18 14:10:02 Loading configuration file: WMP.conf
12-18 14:10:02 Loading configuration file: XBMC.conf
12-18 14:10:02 Loading configuration file: XBOX360.conf
12-18 14:10:02 Loading configuration file: YamahaRXA1010.conf
12-18 14:10:02 Loading configuration file: YamahaRXV671.conf
12-18 14:10:02 Please wait while we check the MPlayer font cache, this can take a minute or so.
12-18 14:10:05 Finished checking the MPlayer font cache.
12-18 14:10:05 VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
12-18 14:10:05 Found VideoLAN version 2.0.4 at: C:\Program Files\VideoLAN\VLC\vlc.exe
12-18 14:10:05 Searching for plugins in C:\Program Files\Universal Media Server\plugins
12-18 14:10:05 No plugins found
12-18 14:10:05 Registering transcoding engine: AviSynth/FFmpeg
12-18 14:10:05 Registering transcoding engine: FFmpeg Audio
12-18 14:10:05 Registering transcoding engine: MEncoder
12-18 14:10:05 Registering transcoding engine: AviSynth/MEncoder
12-18 14:10:05 Registering transcoding engine: MPlayer Audio
12-18 14:10:05 Registering transcoding engine: FFmpeg Web Video
12-18 14:10:05 Registering transcoding engine: MEncoder Web
12-18 14:10:05 Registering transcoding engine: MPlayer Video Dump
12-18 14:10:05 Registering transcoding engine: MPlayer Web
12-18 14:10:05 Registering transcoding engine: tsMuxeR
12-18 14:10:05 Registering transcoding engine: Audio High Fidelity
12-18 14:10:05 Registering transcoding engine: VLC Audio Streaming
12-18 14:10:05 Registering transcoding engine: VLC Video Streaming
12-18 14:10:05 Registering transcoding engine: FFmpeg DVR-MS Remux
12-18 14:10:05 Registering transcoding engine: dcraw Thumbnailer
12-18 14:10:06 Using localhost address
12-18 14:10:06 Created socket: 0.0.0.0/0.0.0.0:5001
12-18 14:10:06 Generated new random UUID: 340e6214-46e6-4a33-9e6c-d669aa33914d
12-18 14:10:06 Configuration saved to: C:\ProgramData\UMS\UMS.conf
12-18 14:10:06 Using the following UUID configured in UMS.conf: 340e6214-46e6-4a33-9e6c-d669aa33914d
12-18 14:10:10 The server is now available for renderers to find
12-18 14:10:50 No IP filter specified, access granted to /192.168.1.2
12-18 14:13:11 Checking IP: 192.168.1.2 for Xbox 360
12-18 14:13:11 Renderer Xbox 360 found on this address: new-host.home (192.168.1.2)
Re: XBox 360 only sees UMS installed on other wireless devic
You could try changing the port on the General Configuration tab, since the default one may be in use by another program
