Universal conf file
matrixebiz
Universal conf file
Post by matrixebiz »
Hello, I'm setting up my Toshiba Blu-ray player with it's own conf file because it just comes up as unknown so I was wondering which conf file can I rename that will show all video formats and play with the best settings? I used/renamed the ps3.conf with my own png graphic but realized that it doesn't list avi's :( so I just need to know which one I can use that has the best settings for a blu-ray player.
What conf does the Unknown Renderer setting use? My avi file plays fine when I just leave it as Unknown but says video unsupported when I select a specific renderer
Re: Universal conf file
Please post your debug.log after playing the avi file using the unknown renderer
matrixebiz
Here you go. Thx
This is the movie that works when I use Unknown Render but does not play when I select one or try to create my own;
Battle Los Angeles {2011} DVDRIP. Jaybob .avi
INFO  2013-01-12 18:28:43.506 [main] An invalid plugin was ignored
INFO  2013-01-12 18:28:44.066 [main] Starting Universal Media Server 2.2.4
INFO  2013-01-12 18:28:44.076 [main] Based on PS3 Media Server by shagrath, copyright 2008-2012
INFO  2013-01-12 18:28:44.076 [main] http://www.universalmediaserver.com
INFO  2013-01-12 18:28:44.086 [main] Build: 6f0e28c8b (2013-01-09)
INFO  2013-01-12 18:28:44.086 [main] Java: 1.7.0_07-Oracle Corporation
INFO  2013-01-12 18:28:44.086 [main] OS: Windows 7 32-bit 6.1
INFO  2013-01-12 18:28:44.086 [main] Encoding: UTF-8
INFO  2013-01-12 18:28:44.086 [main] Memory: 742 MB
INFO  2013-01-12 18:28:44.086 [main] Working directory: C:\Program Files\Universal Media Server
INFO  2013-01-12 18:28:44.096 [main] Temp directory: C:\Users\WINDOW~1\AppData\Local\Temp\universalmediaserver
INFO  2013-01-12 18:28:44.096 [main] Logging config file: C:\Program Files\Universal Media Server\logback.xml
INFO  2013-01-12 18:28:44.096 [main] debug.log: C:\Users\WINDOW~1\AppData\Local\Temp\\debug.log
INFO  2013-01-12 18:28:44.096 [main] Profile directory: C:\ProgramData\UMS
INFO  2013-01-12 18:28:44.096 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2013-01-12 18:28:44.106 [main] Profile permissions: rw
INFO  2013-01-12 18:28:44.106 [main] Profile name: D630
INFO  2013-01-12 18:28:44.106 [main] Loading MediaInfo library
INFO  2013-01-12 18:28:44.216 [main] Loaded MediaInfoLib - v0.7.61
INFO  2013-01-12 18:28:44.216 [main] Loading renderer configurations from C:\Program Files\Universal Media Server\renderers
INFO  2013-01-12 18:28:44.216 [main] Loading configuration file: AirPlayer.conf
INFO  2013-01-12 18:28:44.226 [main] Loading configuration file: Android.conf
INFO  2013-01-12 18:28:44.226 [main] Loading configuration file: Bravia4500.conf
INFO  2013-01-12 18:28:44.226 [main] Loading configuration file: Bravia5500.conf
INFO  2013-01-12 18:28:44.226 [main] Loading configuration file: BraviaEX.conf
INFO  2013-01-12 18:28:44.226 [main] Loading configuration file: BraviaEX620.conf
INFO  2013-01-12 18:28:44.236 [main] Loading configuration file: DirecTVHR.conf
INFO  2013-01-12 18:28:44.236 [main] Loading configuration file: DLinkDSM510.conf
INFO  2013-01-12 18:28:44.236 [main] Loading configuration file: FreeboxHD.conf
INFO  2013-01-12 18:28:44.236 [main] Loading configuration file: FreecomMusicPal.conf
INFO  2013-01-12 18:28:44.246 [main] Loading configuration file: iPad-iPhone.conf
INFO  2013-01-12 18:28:44.246 [main] Loading configuration file: Kuro.conf
INFO  2013-01-12 18:28:44.246 [main] Loading configuration file: LGST600.conf
INFO  2013-01-12 18:28:44.246 [main] Loading configuration file: N900.conf
INFO  2013-01-12 18:28:44.246 [main] Loading configuration file: OPPOBDP83.conf
INFO  2013-01-12 18:28:44.246 [main] Loading configuration file: OPPOBDP93.conf
INFO  2013-01-12 18:28:44.256 [main] Loading configuration file: Panasonic.conf
INFO  2013-01-12 18:28:44.256 [main] Loading configuration file: Philips.conf
INFO  2013-01-12 18:28:44.256 [main] Loading configuration file: PhilipsPFL.conf
INFO  2013-01-12 18:28:44.256 [main] Loading configuration file: PopcornHour.conf
INFO  2013-01-12 18:28:44.256 [main] Loading configuration file: PS3.conf
INFO  2013-01-12 18:28:44.266 [main] Loading configuration file: Realtek.conf
INFO  2013-01-12 18:28:44.266 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO  2013-01-12 18:28:44.266 [main] Loading configuration file: SamsungAllShare.conf
INFO  2013-01-12 18:28:44.266 [main] Loading configuration file: SamsungWiseLink.conf
INFO  2013-01-12 18:28:44.266 [main] Loading configuration file: Showtime3.conf
INFO  2013-01-12 18:28:44.276 [main] Loading configuration file: SMP-N100.conf
INFO  2013-01-12 18:28:44.276 [main] Loading configuration file: SonyBluray.conf
INFO  2013-01-12 18:28:44.276 [main] Loading configuration file: SonyBraviaHX800.conf
INFO  2013-01-12 18:28:44.276 [main] Loading configuration file: Streamium.conf
INFO  2013-01-12 18:28:44.286 [main] Loading configuration file: WDTVLive.conf
INFO  2013-01-12 18:28:44.286 [main] Loading configuration file: WMP.conf
INFO  2013-01-12 18:28:44.286 [main] Loading configuration file: XBMC.conf
INFO  2013-01-12 18:28:44.296 [main] Loading configuration file: Xbox360.conf
INFO  2013-01-12 18:28:44.296 [main] Loading configuration file: YamahaRXA1010.conf
INFO  2013-01-12 18:28:44.296 [main] Loading configuration file: YamahaRXV671.conf
INFO  2013-01-12 18:28:44.296 [main] Please wait while we check the MPlayer font cache, this can take a minute or so.
DEBUG 2013-01-12 18:28:44.296 [main] launching: win32/mplayer.exe
DEBUG 2013-01-12 18:28:44.397 [main] launching: win32/mplayer.exe
INFO  2013-01-12 18:28:44.507 [main] Finished checking the MPlayer font cache.
DEBUG 2013-01-12 18:28:44.507 [main] AviSynth plugins directory: C:\Program Files\FreeTime\FormatFactory\FFModules\AviSynthPlugins
DEBUG 2013-01-12 18:28:44.507 [main] VSFilter / DirectVobSub was found in the AviSynth plugins directory.
INFO  2013-01-12 18:28:44.517 [main] Found VideoLAN version 2.0.4 at: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO  2013-01-12 18:28:44.527 [main] Searching for plugins in C:\Program Files\Universal Media Server\plugins
INFO  2013-01-12 18:28:44.527 [main] No plugins found
INFO  2013-01-12 18:28:44.547 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2013-01-12 18:28:44.547 [main] Registering transcoding engine: FFmpeg Audio
INFO  2013-01-12 18:28:44.547 [main] Registering transcoding engine: MEncoder
INFO  2013-01-12 18:28:44.547 [main] Registering transcoding engine: AviSynth/MEncoder
INFO  2013-01-12 18:28:44.557 [main] Registering transcoding engine: MPlayer Audio
INFO  2013-01-12 18:28:44.557 [main] Registering transcoding engine: FFmpeg Web Video
INFO  2013-01-12 18:28:44.557 [main] Registering transcoding engine: MEncoder Web
INFO  2013-01-12 18:28:44.557 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2013-01-12 18:28:44.557 [main] Registering transcoding engine: MPlayer Web
INFO  2013-01-12 18:28:44.557 [main] Registering transcoding engine: tsMuxeR
INFO  2013-01-12 18:28:44.557 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2013-01-12 18:28:44.557 [main] Found VLC version 2.0.4 in Windows Registry: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO  2013-01-12 18:28:44.557 [main] Registering transcoding engine: VLC Audio Streaming
INFO  2013-01-12 18:28:44.557 [main] Registering transcoding engine: VLC Video Streaming
INFO  2013-01-12 18:28:44.557 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2013-01-12 18:28:44.557 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2013-01-12 18:28:44.627 [main] Using localhost address
INFO  2013-01-12 18:28:44.627 [main] Created socket: 0.0.0.0/0.0.0.0:5001
INFO  2013-01-12 18:28:44.717 [main] Checking shared folder: C:\Users\Windows7U\Videos
DEBUG 2013-01-12 18:28:44.767 [main] Sending ALIVE...
INFO  2013-01-12 18:28:44.847 [main] Using the following UUID configured in UMS.conf: 8856c0c6-f5c7-4ab8-bc97-f3bfe249c77a
INFO  2013-01-12 18:28:46.602 [New I/O server worker #1-1] No IP filter specified, access granted to /192.168.0.12
INFO  2013-01-12 18:28:46.613 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:28:49.771 [main] The server is now available for renderers to find
INFO  2013-01-12 18:28:51.751 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:28:51.801 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:28:52.301 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:28:54.941 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
DEBUG 2013-01-12 18:28:55.281 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "C:\Users\Windows7U\Videos\Battle Los Angeles  {2011} DVDRIP. Jaybob .avi" -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:28:55.311 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-0
DEBUG 2013-01-12 18:28:56.011 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i C:\Users\Windows7U\Videos\djangou.mkv -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:28:56.021 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-1
DEBUG 2013-01-12 18:28:56.441 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "C:\Users\Windows7U\Videos\Flight 2012 DVDSCR x264 AAC-BiGKATS.mp4" -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:28:56.441 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-2
DEBUG 2013-01-12 18:28:57.031 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i C:\Users\Windows7U\Videos\Looper.2012.DVDRip.XviD-PTpOWeR.avi -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:28:57.031 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-3
DEBUG 2013-01-12 18:28:57.742 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i C:\Users\Windows7U\Videos\Resident.Evil.Retribution.2012.DVDRip-Lum1x-.avi -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:28:57.742 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-4
DEBUG 2013-01-12 18:28:58.382 [Buffered IO End Checker] Stopping process: ffmpeg.exe-0
DEBUG 2013-01-12 18:28:58.562 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i C:\Users\Windows7U\Videos\TED.2012.dvdrip.xvid.ac3.avi -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:28:58.562 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-5
DEBUG 2013-01-12 18:28:58.712 [Buffered IO End Checker] Stopping process: ffmpeg.exe-1
DEBUG 2013-01-12 18:28:59.162 [Buffered IO End Checker] Stopping process: ffmpeg.exe-2
DEBUG 2013-01-12 18:28:59.312 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i C:\Users\Windows7U\Videos\The.Eye[2008]DvDrip-aXXo.mkv -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:28:59.312 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-6
DEBUG 2013-01-12 18:28:59.702 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i C:\Users\Windows7U\Videos\The.Hobbit.2012.DVDScr.XVID.AC3.HQ.Hive-CM8.avi -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:28:59.702 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-7
DEBUG 2013-01-12 18:28:59.772 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-01-12 18:28:59.922 [Buffered IO End Checker] Stopping process: ffmpeg.exe-3
DEBUG 2013-01-12 18:28:59.982 [Thread-39] [mpeg4 @ 0031b960] Invalid and inefficient vfw-avi packed B frames detected
DEBUG 2013-01-12 18:28:59.992 [Thread-39]     Last message repeated 1 times
DEBUG 2013-01-12 18:28:59.992 [Thread-39] [mpeg4 @ 0371b0a0] Invalid and inefficient vfw-avi packed B frames detected
DEBUG 2013-01-12 18:29:00.620 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i C:\Users\Windows7U\Videos\The.Hunger.Games.2012.avi -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:29:00.620 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-8
DEBUG 2013-01-12 18:29:00.700 [Buffered IO End Checker] Stopping process: ffmpeg.exe-4
DEBUG 2013-01-12 18:29:01.562 [Buffered IO End Checker] Stopping process: ffmpeg.exe-5
DEBUG 2013-01-12 18:29:01.680 [Thread-43] [mpeg4 @ 01d4b8c0] Invalid and inefficient vfw-avi packed B frames detected
DEBUG 2013-01-12 18:29:01.689 [Thread-43]     Last message repeated 1 times
DEBUG 2013-01-12 18:29:01.689 [Thread-43] [mpeg4 @ 01c3e4c0] Invalid and inefficient vfw-avi packed B frames detected
DEBUG 2013-01-12 18:29:02.002 [Buffered IO End Checker] Stopping process: ffmpeg.exe-6
DEBUG 2013-01-12 18:29:02.237 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "C:\Users\Windows7U\Videos\The Amazing Spiderman {2012} DVDRIP. Jaybob.avi" -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:29:02.240 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-9
DEBUG 2013-01-12 18:29:02.480 [Thread-47] [mpeg4 @ 0039b960] Invalid and inefficient vfw-avi packed B frames detected
DEBUG 2013-01-12 18:29:02.491 [Thread-47]     Last message repeated 1 times
DEBUG 2013-01-12 18:29:02.491 [Thread-47] [mpeg4 @ 03057fe0] Invalid and inefficient vfw-avi packed B frames detected
DEBUG 2013-01-12 18:29:02.702 [Buffered IO End Checker] Stopping process: ffmpeg.exe-7
DEBUG 2013-01-12 18:29:03.039 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "C:\Users\Windows7U\Videos\The Avengers 2012 720p BDRip [A Release-Lounge H264].mp4" -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:29:03.040 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-10
DEBUG 2013-01-12 18:29:03.717 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "C:\Users\Windows7U\Videos\The Book of Eli (2010) DVDRip XviD-MAXSPEED.avi" -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:29:03.717 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-11
DEBUG 2013-01-12 18:29:04.337 [Buffered IO End Checker] Stopping process: ffmpeg.exe-8
DEBUG 2013-01-12 18:29:04.357 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "C:\Users\Windows7U\Videos\The Shawshank Redemption.mp4" -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:29:04.367 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-12
DEBUG 2013-01-12 18:29:04.447 [Thread-59] [image2 @ 02ffc3e0] Frame rate very high for a muxer not efficiently supporting it.
DEBUG 2013-01-12 18:29:04.457 [Thread-59] Please consider specifying a lower framerate, a different muxer or -vsync 2
DEBUG 2013-01-12 18:29:04.717 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "C:\Users\Windows7U\Videos\The Social Network[2010].mkv" -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:29:04.717 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-13
DEBUG 2013-01-12 18:29:05.007 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i C:\Users\Windows7U\Videos\Thir13en.Ghosts[2001]DvDrip-kirklestat.mkv -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:29:05.007 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-14
DEBUG 2013-01-12 18:29:05.137 [Buffered IO End Checker] Stopping process: ffmpeg.exe-9
DEBUG 2013-01-12 18:29:05.977 [Buffered IO End Checker] Stopping process: ffmpeg.exe-10
DEBUG 2013-01-12 18:29:06.067 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "C:\Users\Windows7U\Videos\This is 40 2012 DVD Screener.avi" -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:29:06.067 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-15
DEBUG 2013-01-12 18:29:06.207 [Thread-71] [mpeg4 @ 01aab900] Invalid and inefficient vfw-avi packed B frames detected
DEBUG 2013-01-12 18:29:06.217 [Thread-71]     Last message repeated 1 times
DEBUG 2013-01-12 18:29:06.217 [Thread-71] [mpeg4 @ 0281b4c0] Invalid and inefficient vfw-avi packed B frames detected
DEBUG 2013-01-12 18:29:06.427 [New I/O server worker #1-3] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "C:\Users\Windows7U\Videos\TOTAL RECALL (2012) DVDRip [MKV 6ch AC3][RoB].mkv" -an -an -s 320x180 -vframes 1 -f image2 -loglevel warning pipe:
DEBUG 2013-01-12 18:29:06.437 [New I/O server worker #1-3] Attaching thread: ffmpeg.exe-16
INFO  2013-01-12 18:29:06.557 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:06.587 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:06.617 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
DEBUG 2013-01-12 18:29:06.637 [Buffered IO End Checker] Stopping process: ffmpeg.exe-11
INFO  2013-01-12 18:29:06.677 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:06.787 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
DEBUG 2013-01-12 18:29:07.067 [Buffered IO End Checker] Stopping process: ffmpeg.exe-12
DEBUG 2013-01-12 18:29:07.357 [Buffered IO End Checker] Stopping process: ffmpeg.exe-13
DEBUG 2013-01-12 18:29:07.647 [Buffered IO End Checker] Stopping process: ffmpeg.exe-14
INFO  2013-01-12 18:29:08.608 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:08.628 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:08.638 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:08.648 [StartPlaying Event] Exception in thread "StartPlaying Event" java.lang.NullPointerException
INFO  2013-01-12 18:29:08.648 [StartPlaying Event] 	at net.pms.dlna.DLNAResource$1.run(DLNAResource.java:1542)
INFO  2013-01-12 18:29:08.658 [StartPlaying Event] 	at java.lang.Thread.run(Unknown Source)
INFO  2013-01-12 18:29:08.778 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:08.778 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:08.788 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:08.808 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:08.818 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:08.868 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
DEBUG 2013-01-12 18:29:08.898 [Buffered IO End Checker] Stopping process: ffmpeg.exe-15
DEBUG 2013-01-12 18:29:09.018 [Buffered IO End Checker] Stopping process: ffmpeg.exe-16
INFO  2013-01-12 18:29:09.028 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:09.038 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:09.048 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:09.068 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:09.208 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:09.328 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:09.628 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:09.818 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:10.018 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:10.228 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:10.438 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:10.628 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:10.846 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:11.046 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:11.246 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:11.436 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:11.606 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:11.786 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:11.966 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:12.176 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:12.376 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:12.566 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:12.756 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:12.914 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:13.135 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:13.305 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:13.505 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:13.705 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:13.966 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:14.186 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:14.356 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:15.744 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:15.974 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:22.524 [UPNPHelper] No IP filter specified, access granted to /192.168.0.1
DEBUG 2013-01-12 18:29:25.864 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2013-01-12 18:29:48.042 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:48.122 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:48.272 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:48.302 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:48.432 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:48.572 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50, friendlyName.dlna.org: BD-Player
INFO  2013-01-12 18:29:49.682 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: IPI/1.0 UPnP/1.0 DLNADOC/1.50
INFO  2013-01-12 18:29:53.672 [StopPlaying Event] Exception in thread "StopPlaying Event" java.lang.NullPointerException
INFO  2013-01-12 18:29:53.672 [StopPlaying Event] 	at net.pms.dlna.DLNAResource$2$1.run(DLNAResource.java:1604)
INFO  2013-01-12 18:29:53.682 [StopPlaying Event] 	at java.lang.Thread.run(Unknown Source)
matrixebiz
Does the creator of UMS come on this board? He should be able to know the answer to this right away.
I just need to know what to put in the conf file to play all videos like the Unknown Renderer setting does.
matrixebiz
Any ideas?
lemtargatwing
Post by lemtargatwing »
The one who asked you to post the debug.log file is the creator of UMS. And to be able to detect the renderer properly you will have to set up the conf with correct identifying headers that way UMS knows what it is looking for.
matrixebiz
Yes, I did do that but now I need to know how to setup the "Supported video formats" section so that it will play everything like when I use the "Unknown Renderer" selection. I could just leave my UMS settings at Unknown Renderer but I like having my own conf file with my DVD png picture.
