[Fixed] ALL Files Show As MPEG After Update to 2.2.x
AYColumbia
Post by AYColumbia »
Is anyone else having this problem after upgrading to 2.2.x? I happen to have an Oppo BDP-103 which worked fine with 2.1.2.
The details of this issue are available here as I reported it.
Raker13
Re: ALL Files Show As MPEG After Update to 2.2.x
Post by Raker13 »
Yes, I have the same issue. I have a OPPO 93. All files show as MPEG and for some strange reason, no transcode engines are showing in the transcode folder. I am not hiding the transcode engine names. I have not been able to use any 2.2.X program.
I too, have to revert to 2.1.2 to get the program to show MKV's as MKV's. All transcode engine names are also in the transcode folder with 2.1.2.
I am not good with code, but I have looked at all the conf files that seem applicable. Still stumped.
Everything is working fine (some minor A/V sync issues after an extended pause while transcoding some non-MKV files I have i.e., MPEG) with 2.1.2
Is it fixed in 2.2.2?
AYColumbia
SubJunk wrote:Is it fixed in 2.2.2?
Sorry I've been MIA for a bit. Buried with work. I just grabbed 2.2.5 and will report back in a little while. Thank you.
AYColumbia
Definitely fixed in 2.2.5. Thank you very much. :D
Great, thanks for confirming :)
