[Fixed] Missing Renderers in Transcode Folder + CPU thread
V4mP123
Post by V4mP123 »
Problem with Versions: 2.2.0, 2.2.1 and 2.2.2
Error: In Transcode folder are only Following Entrys:
1) Main Entry (Name of the Video File)
2) [No Encoding]
3) Chapter [No Encoding] --> Because I have enabled the "Transcode folder chapter support"
( Prior Versions e.g. 2.1.2 Show me Mencoder/Avisynth/FFMPEG and per Entry the Chapter Folder)
I'm Streaming on a Samsung SmartTV ue37d6500.
For the time beeing I'll stick with Version 2.1.2. Hope you can reconstruct and fix the Problem ;-)
PS: Just to mention one other Topic here in this Forum: I have to set the "CPU threads to use when enabled for engine" for my Intel machines to the physical core count (i7 4; i5 2); otherwise I get a "Java Array index out of bounds exception" while Transcoding with Mencoder. I have this Problem since I used PMS and UMS (~2years). So this is a inherited PMS Problem.
Re: Missing Renderers in Transcode Folder
We are working on the transcode folder bug. Can you please post a debug log after reproducing the out of bounds exception?
V4mP123
Post by V4mP123 »
I have reproduced the error by setting CPU threads to 8 again (on my i7 860):
I started transcoding a video with Mencoder; @ second 11 the video ends.
INFO  2013-01-07 19:29:37.746 [New I/O server worker #1-2] Buffer read ArrayIndexOutOfBoundsException error:
INFO  2013-01-07 19:29:37.746 [New I/O server worker #1-2] readCount: "99996000000"
INFO  2013-01-07 19:29:37.747 [New I/O server worker #1-2] maxMemorySize: "419430400"
INFO  2013-01-07 19:29:37.772 [New I/O server worker #1-3] Buffer read ArrayIndexOutOfBoundsException error:
INFO  2013-01-07 19:29:37.772 [New I/O server worker #1-3] readCount: "99996000000"
INFO  2013-01-07 19:29:37.772 [New I/O server worker #1-3] maxMemorySize: "419430400"
DEBUG 2013-01-07 19:29:47.755 [Buffered IO End Checker] Stopping process: mencoder.exe-20
Some facts:
- Avisynth is not affected
- Problem does not occur with "CPU threads to use when enabled for engine: (it seems you have 8)" set to 4
- Same problem with PMS
full log:
INFO  2013-01-07 19:27:00.687 [main] An invalid plugin was ignored
INFO  2013-01-07 19:27:01.057 [main] Starting Universal Media Server 2.1.2
INFO  2013-01-07 19:27:01.064 [main] Based on PS3 Media Server by shagrath, copyright 2008-2012
INFO  2013-01-07 19:27:01.068 [main] http://www.universalmediaserver.com
INFO  2013-01-07 19:27:01.069 [main]
INFO  2013-01-07 19:27:01.069 [main] Build: 1965bcc80 (2012-12-01)
INFO  2013-01-07 19:27:01.070 [main] Java: 1.7.0_10-Oracle Corporation
INFO  2013-01-07 19:27:01.072 [main] OS: Windows 7 64-bit 6.1
INFO  2013-01-07 19:27:01.073 [main] Encoding: UTF-8
INFO  2013-01-07 19:27:01.074 [main] Memory: 742 MB
INFO  2013-01-07 19:27:01.075 [main]
INFO  2013-01-07 19:27:01.075 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2013-01-07 19:27:01.080 [main] Temp directory: C:\Users\User1\AppData\Local\Temp\universalmediaserver
INFO  2013-01-07 19:27:01.081 [main] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2013-01-07 19:27:01.082 [main] debug.log: C:\Users\User1\AppData\Local\Temp\\debug.log
INFO  2013-01-07 19:27:01.083 [main]
INFO  2013-01-07 19:27:01.083 [main] Profile directory: C:\ProgramData\UMS
INFO  2013-01-07 19:27:01.083 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2013-01-07 19:27:01.084 [main] Profile permissions: rw
INFO  2013-01-07 19:27:01.084 [main] Profile name: MyMachine
INFO  2013-01-07 19:27:01.085 [main]
INFO  2013-01-07 19:27:01.089 [main] Loading MediaInfo library
INFO  2013-01-07 19:27:01.174 [main] Loaded MediaInfoLib - v0.7.61
INFO  2013-01-07 19:27:01.177 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO  2013-01-07 19:27:01.178 [main] Loading configuration file: AirPlayer.conf
INFO  2013-01-07 19:27:01.180 [main] Loading configuration file: Android.conf
INFO  2013-01-07 19:27:01.181 [main] Loading configuration file: Bravia4500.conf
INFO  2013-01-07 19:27:01.183 [main] Loading configuration file: Bravia5500.conf
INFO  2013-01-07 19:27:01.184 [main] Loading configuration file: BraviaEX.conf
INFO  2013-01-07 19:27:01.186 [main] Loading configuration file: BraviaEX620.conf
INFO  2013-01-07 19:27:01.188 [main] Loading configuration file: DirecTVHR.conf
INFO  2013-01-07 19:27:01.195 [main] Loading configuration file: DLinkDSM510.conf
INFO  2013-01-07 19:27:01.197 [main] Loading configuration file: FreeboxHD.conf
INFO  2013-01-07 19:27:01.198 [main] Loading configuration file: FreecomMusicPal.conf
INFO  2013-01-07 19:27:01.199 [main] Loading configuration file: iPad-iPhone.conf
INFO  2013-01-07 19:27:01.200 [main] Loading configuration file: Kuro.conf
INFO  2013-01-07 19:27:01.202 [main] Loading configuration file: LGST600.conf
INFO  2013-01-07 19:27:01.204 [main] Loading configuration file: N900.conf
INFO  2013-01-07 19:27:01.205 [main] Loading configuration file: OPPOBDP83.conf
INFO  2013-01-07 19:27:01.206 [main] Loading configuration file: OPPOBDP93.conf
INFO  2013-01-07 19:27:01.207 [main] Loading configuration file: Panasonic.conf
INFO  2013-01-07 19:27:01.209 [main] Loading configuration file: Philips.conf
INFO  2013-01-07 19:27:01.210 [main] Loading configuration file: PhilipsPFL.conf
INFO  2013-01-07 19:27:01.212 [main] Loading configuration file: PopcornHour.conf
INFO  2013-01-07 19:27:01.213 [main] Loading configuration file: PS3.conf
INFO  2013-01-07 19:27:01.215 [main] Loading configuration file: Realtek.conf
INFO  2013-01-07 19:27:01.216 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO  2013-01-07 19:27:01.218 [main] Loading configuration file: SamsungAllShare.conf
INFO  2013-01-07 19:27:01.219 [main] Loading configuration file: SamsungWiseLink.conf
INFO  2013-01-07 19:27:01.220 [main] Loading configuration file: Showtime3.conf
INFO  2013-01-07 19:27:01.222 [main] Loading configuration file: SMP-N100.conf
INFO  2013-01-07 19:27:01.223 [main] Loading configuration file: SonyBluray.conf
INFO  2013-01-07 19:27:01.224 [main] Loading configuration file: SonyBraviaHX800.conf
INFO  2013-01-07 19:27:01.226 [main] Loading configuration file: Streamium.conf
INFO  2013-01-07 19:27:01.227 [main] Loading configuration file: WDTVLive.conf
INFO  2013-01-07 19:27:01.228 [main] Loading configuration file: WMP.conf
INFO  2013-01-07 19:27:01.229 [main] Loading configuration file: XBMC.conf
INFO  2013-01-07 19:27:01.230 [main] Loading configuration file: XBOX360.conf
INFO  2013-01-07 19:27:01.231 [main] Loading configuration file: YamahaRXA1010.conf
INFO  2013-01-07 19:27:01.232 [main] Loading configuration file: YamahaRXV671.conf
INFO  2013-01-07 19:27:01.233 [main] Please wait while we check the MPlayer font cache, this can take a minute or so.
DEBUG 2013-01-07 19:27:01.234 [main] launching: win32/mplayer.exe
DEBUG 2013-01-07 19:27:01.309 [main] launching: win32/mplayer.exe
INFO  2013-01-07 19:27:01.384 [main] Finished checking the MPlayer font cache.
DEBUG 2013-01-07 19:27:01.385 [main] AviSynth plugins directory: C:\Program Files (x86)\AviSynth 2.5\plugins
DEBUG 2013-01-07 19:27:01.385 [main] VSFilter / DirectVobSub was found in the AviSynth plugins directory.
INFO  2013-01-07 19:27:01.396 [main] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2013-01-07 19:27:01.397 [main] No plugins found
INFO  2013-01-07 19:27:01.409 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2013-01-07 19:27:01.410 [main] Registering transcoding engine: FFmpeg Audio
INFO  2013-01-07 19:27:01.415 [main] Registering transcoding engine: MEncoder
INFO  2013-01-07 19:27:01.415 [main] Registering transcoding engine: AviSynth/MEncoder
INFO  2013-01-07 19:27:01.416 [main] Registering transcoding engine: FFmpeg
INFO  2013-01-07 19:27:01.417 [main] Registering transcoding engine: MPlayer Audio
INFO  2013-01-07 19:27:01.418 [main] Registering transcoding engine: FFmpeg Web Video
INFO  2013-01-07 19:27:01.418 [main] Registering transcoding engine: MEncoder Web
INFO  2013-01-07 19:27:01.419 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2013-01-07 19:27:01.419 [main] Registering transcoding engine: MPlayer Web
INFO  2013-01-07 19:27:01.421 [main] Registering transcoding engine: tsMuxeR
INFO  2013-01-07 19:27:01.422 [main] Registering transcoding engine: Audio High Fidelity
INFO  2013-01-07 19:27:01.422 [main] Executable of transcoder profile VLC Audio Streaming not found
INFO  2013-01-07 19:27:01.423 [main] Executable of transcoder profile VLC Video Streaming not found
INFO  2013-01-07 19:27:01.423 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2013-01-07 19:27:01.424 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2013-01-07 19:27:01.537 [main] Using forced address 192.168.1.3
INFO  2013-01-07 19:27:01.537 [main] Created socket: /192.168.1.3:5001
INFO  2013-01-07 19:27:01.592 [main] Checking shared folder: H:\Movies
DEBUG 2013-01-07 19:27:01.627 [main] Sending ALIVE...
INFO  2013-01-07 19:27:02.161 [main] Using the following UUID configured in UMS.conf: d5fbba93-7863-4cd0-9864-07e9e29b7473
INFO  2013-01-07 19:27:05.916 [main] The server is now available for renderers to find
DEBUG 2013-01-07 19:27:15.923 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2013-01-07 19:27:19.512 [New I/O server worker #1-1] No IP filter specified, access granted to /192.168.1.4
DEBUG 2013-01-07 19:27:39.653 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2013-01-07 19:28:11.545 [UPNPHelper] No IP filter specified, access granted to /192.168.1.5
INFO  2013-01-07 19:28:11.608 [pool-7-thread-1] Checking IP: 192.168.1.5 for Samsung AllShare
DEBUG 2013-01-07 19:28:16.241 [New I/O server worker #1-3] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2013-01-07 19:28:16.257 [New I/O server worker #1-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2013-01-07 19:28:16.272 [New I/O server worker #1-5] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
INFO  2013-01-07 19:28:16.303 [New I/O server worker #1-6] Checking shared folder: H:\Movies
INFO  2013-01-07 19:28:16.584 [pool-7-thread-1] Renderer Samsung AllShare found on this address: 192.168.1.5
DEBUG 2013-01-07 19:28:16.584 [pool-7-thread-1] Starting ping -n 3 -l 64000 192.168.1.5
DEBUG 2013-01-07 19:28:18.597 [SpeedStats Failsafe] Stopping process: ping-0
INFO  2013-01-07 19:28:18.597 [pool-7-thread-1] Address /192.168.1.5 has an estimated network speed of: 15 Mb/s
DEBUG 2013-01-07 19:28:27.926 [pool-17-thread-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 01 _9F4D9C67_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:28.004 [pool-17-thread-1] Attaching thread: ffmpeg.exe-1
DEBUG 2013-01-07 19:28:28.550 [pool-18-thread-2] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 04 _10FF2449_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:28.550 [pool-18-thread-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 03 _1C4E010C_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:28.550 [pool-18-thread-3] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 02 _D8E33489_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:28.565 [pool-18-thread-2] Attaching thread: ffmpeg.exe-2
DEBUG 2013-01-07 19:28:28.565 [pool-18-thread-1] Attaching thread: ffmpeg.exe-3
DEBUG 2013-01-07 19:28:28.565 [pool-18-thread-3] Attaching thread: ffmpeg.exe-4
DEBUG 2013-01-07 19:28:29.548 [pool-18-thread-2] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 05 _53D3D968_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:29.548 [pool-18-thread-3] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 06 _F52FCA0E_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:29.595 [pool-18-thread-2] Attaching thread: ffmpeg.exe-5
DEBUG 2013-01-07 19:28:29.595 [pool-18-thread-3] Attaching thread: ffmpeg.exe-6
DEBUG 2013-01-07 19:28:29.595 [pool-18-thread-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 07 _6D60F2EB_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:29.595 [pool-18-thread-1] Attaching thread: ffmpeg.exe-7
DEBUG 2013-01-07 19:28:30.593 [pool-18-thread-2] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 08 _644003BA_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:30.593 [pool-18-thread-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 09_HorribleSubs_ KC - 09 _720p_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:30.593 [pool-18-thread-2] Attaching thread: ffmpeg.exe-8
DEBUG 2013-01-07 19:28:30.593 [pool-18-thread-1] Attaching thread: ffmpeg.exe-9
DEBUG 2013-01-07 19:28:30.609 [pool-18-thread-3] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 10 _8B3B9C00_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:30.609 [pool-18-thread-3] Attaching thread: ffmpeg.exe-10
DEBUG 2013-01-07 19:28:31.014 [Buffered IO End Checker] Stopping process: ffmpeg.exe-1
DEBUG 2013-01-07 19:28:31.233 [pool-18-thread-3] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 11_CR_ KC - 11 _1280x720_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:31.233 [pool-18-thread-3] Attaching thread: ffmpeg.exe-11
DEBUG 2013-01-07 19:28:31.467 [pool-18-thread-2] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 12 _A66F4F79_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:31.467 [pool-18-thread-2] Attaching thread: ffmpeg.exe-12
DEBUG 2013-01-07 19:28:31.482 [pool-18-thread-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\_Commie_ KC - 13 _337975D7_.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:31.482 [pool-18-thread-1] Attaching thread: ffmpeg.exe-13
DEBUG 2013-01-07 19:28:31.794 [pool-18-thread-3] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\SP [rori]_KC_-_14_[52CE936C].mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:31.794 [pool-18-thread-3] Attaching thread: ffmpeg.exe-14
DEBUG 2013-01-07 19:28:32.044 [Buffered IO End Checker] Stopping process: ffmpeg.exe-2
DEBUG 2013-01-07 19:28:32.044 [Buffered IO End Checker] Stopping process: ffmpeg.exe-4
DEBUG 2013-01-07 19:28:32.044 [Buffered IO End Checker] Stopping process: ffmpeg.exe-3
DEBUG 2013-01-07 19:28:32.450 [pool-18-thread-2] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\SP [rori]_KC_-_15_[665BBB46].mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:32.450 [pool-18-thread-2] Attaching thread: ffmpeg.exe-15
DEBUG 2013-01-07 19:28:32.496 [pool-18-thread-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\SP [rori]_KC_-_16_[9B9450D8].mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:32.512 [pool-18-thread-1] Attaching thread: ffmpeg.exe-16
DEBUG 2013-01-07 19:28:32.730 [pool-18-thread-3] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -ss 2 -i "H:\Movies\KC\SP [rori]_KC_-_17_[64BDA734].mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2013-01-07 19:28:32.730 [pool-18-thread-3] Attaching thread: ffmpeg.exe-17
DEBUG 2013-01-07 19:28:33.089 [Buffered IO End Checker] Stopping process: ffmpeg.exe-5
DEBUG 2013-01-07 19:28:33.089 [Buffered IO End Checker] Stopping process: ffmpeg.exe-7
DEBUG 2013-01-07 19:28:33.089 [Buffered IO End Checker] Stopping process: ffmpeg.exe-6
DEBUG 2013-01-07 19:28:33.729 [Buffered IO End Checker] Stopping process: ffmpeg.exe-10
DEBUG 2013-01-07 19:28:33.900 [Buffered IO End Checker] Stopping process: ffmpeg.exe-8
DEBUG 2013-01-07 19:28:33.900 [Buffered IO End Checker] Stopping process: ffmpeg.exe-9
DEBUG 2013-01-07 19:28:34.212 [Buffered IO End Checker] Stopping process: ffmpeg.exe-11
DEBUG 2013-01-07 19:28:34.712 [Buffered IO End Checker] Stopping process: ffmpeg.exe-12
DEBUG 2013-01-07 19:28:35.008 [Buffered IO End Checker] Stopping process: ffmpeg.exe-13
DEBUG 2013-01-07 19:28:35.226 [Buffered IO End Checker] Stopping process: ffmpeg.exe-14
DEBUG 2013-01-07 19:28:35.289 [Buffered IO End Checker] Stopping process: ffmpeg.exe-15
DEBUG 2013-01-07 19:28:35.445 [Buffered IO End Checker] Stopping process: ffmpeg.exe-16
DEBUG 2013-01-07 19:28:35.538 [Buffered IO End Checker] Stopping process: ffmpeg.exe-17
DEBUG 2013-01-07 19:28:39.735 [pool-19-thread-1] Duplicate _Commie_ KC - 01 _9F4D9C67_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.766 [pool-20-thread-2] Duplicate _Commie_ KC - 02 _D8E33489_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.766 [pool-20-thread-1] Duplicate _Commie_ KC - 04 _10FF2449_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.766 [pool-20-thread-3] Duplicate _Commie_ KC - 03 _1C4E010C_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.766 [pool-20-thread-2] Duplicate _Commie_ KC - 05 _53D3D968_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.766 [pool-20-thread-1] Duplicate _Commie_ KC - 06 _F52FCA0E_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.766 [pool-20-thread-3] Duplicate _Commie_ KC - 07 _6D60F2EB_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.766 [pool-20-thread-2] Duplicate _Commie_ KC - 08 _644003BA_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.766 [pool-20-thread-1] Duplicate _Commie_ KC - 09_HorribleSubs_ KC - 09 _720p_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.766 [pool-20-thread-3] Duplicate _Commie_ KC - 10 _8B3B9C00_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.782 [pool-20-thread-1] Duplicate _Commie_ KC - 11_CR_ KC - 11 _1280x720_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.782 [pool-20-thread-3] Duplicate _Commie_ KC - 13 _337975D7_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.782 [pool-20-thread-2] Duplicate _Commie_ KC - 12 _A66F4F79_.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.782 [pool-20-thread-1] Duplicate SP [rori]_KC_-_14_[52CE936C].mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.782 [pool-20-thread-2] Duplicate SP [rori]_KC_-_15_[665BBB46].mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.782 [pool-20-thread-3] Duplicate SP [rori]_KC_-_16_[9B9450D8].mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2013-01-07 19:28:39.782 [pool-20-thread-1] Duplicate SP [rori]_KC_-_17_[64BDA734].mkv for direct streaming to renderer: Samsung AllShare
INFO  2013-01-07 19:28:48.362 [New I/O server worker #1-5] Starting transcode/remux of _Commie_ KC - 01 _9F4D9C67_.mkv
DEBUG 2013-01-07 19:28:48.455 [New I/O server worker #1-5] Creating pipe \\.\pipe\mencoder1357583328455
DEBUG 2013-01-07 19:28:48.533 [Thread-81] Waiting for pipe connection \\.\pipe\mencoder1357583328455
DEBUG 2013-01-07 19:28:48.596 [mencoder.exe-18] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 "H:\Movies\KC\_Commie_ KC - 01 _9F4D9C67_.mkv" -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=8 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=448:threads=8:keyint=5:vqscale=1:vqmin=2:vrc_maxrate=11000:vrc_buf_size=1835 -ass -fontconfig -sid 0 -ofps 24000/1001 -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o \\.\pipe\mencoder1357583328455
INFO  2013-01-07 19:28:48.767 [UPNPHelper] No IP filter specified, access granted to /192.168.1.3
DEBUG 2013-01-07 19:28:48.861 [mencoder.exe-18] Reading pipe: \\.\pipe\mencoder1357583328455
DEBUG 2013-01-07 19:28:48.861 [mencoder.exe-18] Attaching thread: mencoder.exe-18
DEBUG 2013-01-07 19:28:48.876 [Thread-85] MEncoder SB44 (C) 2000-2012 MPlayer Team
DEBUG 2013-01-07 19:28:48.876 [Thread-85] Custom build by SubJunk, http://www.spirton.com
DEBUG 2013-01-07 19:28:48.892 [Thread-85] success: format: 0  data: 0x0 - 0xccf8b3a
DEBUG 2013-01-07 19:28:48.892 [Thread-85] libavformat version 54.40.100 (internal)
DEBUG 2013-01-07 19:28:48.914 [Thread-85] libavformat file format detected.
DEBUG 2013-01-07 19:28:48.985 [Thread-85] [lavf] stream 0: video (h264), -vid 0
DEBUG 2013-01-07 19:28:48.985 [Thread-85] [lavf] stream 1: audio (aac), -aid 0, -alang jpn, Commie
DEBUG 2013-01-07 19:28:48.985 [Thread-85] [lavf] stream 2: subtitle (ass), -sid 0
DEBUG 2013-01-07 19:28:48.986 [Thread-85] VIDEO:  [H264]  1280x720  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
DEBUG 2013-01-07 19:28:48.988 [Thread-85] [V] filefmt:44  fourcc:0x34363248  size:1280x720  fps:23.976  ftime:=0.0417
DEBUG 2013-01-07 19:28:48.988 [Thread-85] ==========================================================================
DEBUG 2013-01-07 19:28:48.993 [Thread-85] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2013-01-07 19:28:48.994 [Thread-85] libavcodec version 54.77.101 (internal)
DEBUG 2013-01-07 19:28:48.999 [Thread-85] AUDIO: 48000 Hz, 2 ch, floatle, 0.0 kbit/0.00% (ratio: 0->384000)
DEBUG 2013-01-07 19:28:48.999 [Thread-85] Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
DEBUG 2013-01-07 19:28:48.999 [Thread-85] ==========================================================================
DEBUG 2013-01-07 19:28:48.999 [Thread-81] Result of \\.\pipe\mencoder1357583328455 : true
DEBUG 2013-01-07 19:28:49.001 [Thread-85] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2013-01-07 19:28:49.003 [Thread-85] Opening video filter: [ass auto=1]
DEBUG 2013-01-07 19:28:49.003 [Thread-85] [ass] auto-open
DEBUG 2013-01-07 19:28:49.031 [Thread-85] ==========================================================================
DEBUG 2013-01-07 19:28:49.037 [Thread-85] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2013-01-07 19:28:49.040 [Thread-85] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2013-01-07 19:28:49.040 [Thread-85] ==========================================================================
DEBUG 2013-01-07 19:28:49.041 [Thread-84] [ac3 @ 0114ec60]Channel layout not specified
DEBUG 2013-01-07 19:28:49.041 [Thread-84] [ac3 @ 0114ec60]No channel layout specified. The encoder will guess the layout, but it might be incorrect.
DEBUG 2013-01-07 19:28:49.042 [Thread-84] Limiting audio preload to 0.4s.
DEBUG 2013-01-07 19:28:49.042 [Thread-84] Increasing audio density to 4.
DEBUG 2013-01-07 19:28:49.052 [Thread-85] Could not find matching colorspace - retrying with -vf scale...
DEBUG 2013-01-07 19:28:49.053 [Thread-85] Opening video filter: [scale]
DEBUG 2013-01-07 19:28:49.053 [Thread-85] Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
DEBUG 2013-01-07 19:28:49.054 [Thread-85] [swscaler @ 0129a300]using unscaled yuv420p10le -> yuv420p special converter
DEBUG 2013-01-07 19:28:49.055 [Thread-85] videocodec: libavcodec (1280x720 fourcc=3267706d [mpg2])
DEBUG 2013-01-07 19:28:49.055 [Thread-85] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2013-01-07 19:28:49.161 [Thread-85] Writing header...
DEBUG 2013-01-07 19:28:49.161 [Thread-85] INITV: 0.200, 0.158, fps: 23.976
DEBUG 2013-01-07 19:28:53.444 [Thread-85]
DEBUG 2013-01-07 19:28:53.444 [Thread-85] Flushing video frames.
DEBUG 2013-01-07 19:28:53.449 [Thread-85] Writing index...
DEBUG 2013-01-07 19:28:53.449 [Thread-85] Overhead: 1.732% (200068 / 11551356)
DEBUG 2013-01-07 19:28:53.449 [Thread-85] Writing header...
DEBUG 2013-01-07 19:28:53.449 [Thread-85] Video stream: 7389.107 kbit/s  (923638 B/s)  size: 10940650 bytes  11.845 secs  294 frames
DEBUG 2013-01-07 19:28:53.449 [Thread-85] Audio stream:  448.000 kbit/s  (55999 B/s)  size: 686336 bytes  12.256 secs
INFO  2013-01-07 19:28:54.714 [StartPlaying Event] Started playing _Commie_ KC - 01 _9F4D9C67_.mkv on your Samsung AllShare
DEBUG 2013-01-07 19:28:54.714 [StartPlaying Event] The full filename of which is: H:\Movies\KC\_Commie_ KC - 01 _9F4D9C67_.mkv and the address of the renderer is: 192.168.1.5
DEBUG 2013-01-07 19:28:55.010 [New I/O server worker #1-7] Setting InputStream new position to: 32,768
DEBUG 2013-01-07 19:28:55.104 [New I/O server worker #1-8] Setting InputStream new position to: 65,536
DEBUG 2013-01-07 19:28:55.197 [New I/O server worker #1-9] Setting InputStream new position to: 98,304
DEBUG 2013-01-07 19:28:55.260 [New I/O server worker #1-10] Setting InputStream new position to: 131,072
DEBUG 2013-01-07 19:28:55.385 [New I/O server worker #1-11] Setting InputStream new position to: 163,840
DEBUG 2013-01-07 19:28:55.478 [New I/O server worker #1-12] Setting InputStream new position to: 196,608
DEBUG 2013-01-07 19:28:55.541 [New I/O server worker #1-13] Setting InputStream new position to: 229,376
DEBUG 2013-01-07 19:28:55.619 [New I/O server worker #1-14] Setting InputStream new position to: 262,144
DEBUG 2013-01-07 19:28:55.697 [New I/O server worker #1-15] Setting InputStream new position to: 294,912
DEBUG 2013-01-07 19:28:55.775 [New I/O server worker #1-16] Setting InputStream new position to: 327,680
DEBUG 2013-01-07 19:28:55.868 [New I/O server worker #1-1] Setting InputStream new position to: 360,448
DEBUG 2013-01-07 19:28:55.962 [New I/O server worker #1-2] Setting InputStream new position to: 393,216
DEBUG 2013-01-07 19:28:56.040 [New I/O server worker #1-3] Setting InputStream new position to: 425,984
DEBUG 2013-01-07 19:28:56.102 [New I/O server worker #1-4] Setting InputStream new position to: 458,752
DEBUG 2013-01-07 19:28:56.180 [New I/O server worker #1-5] Setting InputStream new position to: 491,520
DEBUG 2013-01-07 19:28:56.243 [New I/O server worker #1-6] Setting InputStream new position to: 524,288
DEBUG 2013-01-07 19:28:56.305 [New I/O server worker #1-7] Setting InputStream new position to: 557,056
DEBUG 2013-01-07 19:28:56.383 [New I/O server worker #1-8] Setting InputStream new position to: 589,824
DEBUG 2013-01-07 19:28:56.461 [New I/O server worker #1-9] Setting InputStream new position to: 622,592
DEBUG 2013-01-07 19:28:56.508 [New I/O server worker #1-10] Setting InputStream new position to: 655,360
DEBUG 2013-01-07 19:28:56.586 [New I/O server worker #1-11] Setting InputStream new position to: 688,128
DEBUG 2013-01-07 19:28:56.664 [New I/O server worker #1-12] Setting InputStream new position to: 720,896
DEBUG 2013-01-07 19:28:56.742 [New I/O server worker #1-13] Setting InputStream new position to: 753,664
DEBUG 2013-01-07 19:28:56.820 [New I/O server worker #1-14] Setting InputStream new position to: 786,432
DEBUG 2013-01-07 19:28:56.898 [New I/O server worker #1-15] Setting InputStream new position to: 819,200
DEBUG 2013-01-07 19:28:56.960 [New I/O server worker #1-16] Setting InputStream new position to: 851,968
DEBUG 2013-01-07 19:28:57.054 [New I/O server worker #1-1] Setting InputStream new position to: 884,736
DEBUG 2013-01-07 19:28:57.179 [New I/O server worker #1-2] Setting InputStream new position to: 917,504
DEBUG 2013-01-07 19:28:57.241 [New I/O server worker #1-3] Setting InputStream new position to: 950,272
DEBUG 2013-01-07 19:28:57.319 [New I/O server worker #1-4] Setting InputStream new position to: 983,040
DEBUG 2013-01-07 19:28:57.397 [New I/O server worker #1-5] Setting InputStream new position to: 1,015,808
DEBUG 2013-01-07 19:28:57.522 [Buffered IO End Checker] Stopping process: mencoder.exe-18
INFO  2013-01-07 19:28:57.522 [New I/O server worker #1-7] Starting transcode/remux of _Commie_ KC - 01 _9F4D9C67_.mkv
DEBUG 2013-01-07 19:28:57.553 [New I/O server worker #1-7] Creating pipe \\.\pipe\mencoder1357583337553
DEBUG 2013-01-07 19:28:57.600 [Thread-86] Waiting for pipe connection \\.\pipe\mencoder1357583337553
DEBUG 2013-01-07 19:28:57.662 [mencoder.exe-19] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 "H:\Movies\KC\_Commie_ KC - 01 _9F4D9C67_.mkv" -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=8 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=448:threads=8:keyint=5:vqscale=1:vqmin=2:vrc_maxrate=11000:vrc_buf_size=1835 -ass -fontconfig -sid 0 -ofps 24000/1001 -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o \\.\pipe\mencoder1357583337553
DEBUG 2013-01-07 19:28:57.662 [mencoder.exe-19] Reading pipe: \\.\pipe\mencoder1357583337553
DEBUG 2013-01-07 19:28:57.662 [mencoder.exe-19] Attaching thread: mencoder.exe-19
DEBUG 2013-01-07 19:28:57.678 [Thread-90] MEncoder SB44 (C) 2000-2012 MPlayer Team
DEBUG 2013-01-07 19:28:57.678 [Thread-90] Custom build by SubJunk, http://www.spirton.com
DEBUG 2013-01-07 19:28:57.693 [Thread-90] success: format: 0  data: 0x0 - 0xccf8b3a
DEBUG 2013-01-07 19:28:57.693 [Thread-90] libavformat version 54.40.100 (internal)
DEBUG 2013-01-07 19:28:57.693 [Thread-90] libavformat file format detected.
DEBUG 2013-01-07 19:28:57.775 [Thread-90] [lavf] stream 0: video (h264), -vid 0
DEBUG 2013-01-07 19:28:57.775 [Thread-90] [lavf] stream 1: audio (aac), -aid 0, -alang jpn, Commie
DEBUG 2013-01-07 19:28:57.775 [Thread-90] [lavf] stream 2: subtitle (ass), -sid 0
DEBUG 2013-01-07 19:28:57.776 [Thread-90] VIDEO:  [H264]  1280x720  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
DEBUG 2013-01-07 19:28:57.777 [Thread-90] [V] filefmt:44  fourcc:0x34363248  size:1280x720  fps:23.976  ftime:=0.0417
DEBUG 2013-01-07 19:28:57.778 [Thread-90] ==========================================================================
DEBUG 2013-01-07 19:28:57.778 [Thread-90] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2013-01-07 19:28:57.778 [Thread-90] libavcodec version 54.77.101 (internal)
DEBUG 2013-01-07 19:28:57.779 [Thread-90] AUDIO: 48000 Hz, 2 ch, floatle, 0.0 kbit/0.00% (ratio: 0->384000)
DEBUG 2013-01-07 19:28:57.779 [Thread-90] Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
DEBUG 2013-01-07 19:28:57.779 [Thread-90] ==========================================================================
DEBUG 2013-01-07 19:28:57.779 [Thread-86] Result of \\.\pipe\mencoder1357583337553 : true
DEBUG 2013-01-07 19:28:57.780 [Thread-90] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2013-01-07 19:28:57.780 [Thread-90] Opening video filter: [ass auto=1]
DEBUG 2013-01-07 19:28:57.781 [Thread-90] [ass] auto-open
DEBUG 2013-01-07 19:28:57.799 [Thread-90] ==========================================================================
DEBUG 2013-01-07 19:28:57.799 [Thread-90] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2013-01-07 19:28:57.802 [Thread-90] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2013-01-07 19:28:57.802 [Thread-90] ==========================================================================
DEBUG 2013-01-07 19:28:57.802 [Thread-89] [ac3 @ 0114ec60]Channel layout not specified
DEBUG 2013-01-07 19:28:57.802 [Thread-89] [ac3 @ 0114ec60]No channel layout specified. The encoder will guess the layout, but it might be incorrect.
DEBUG 2013-01-07 19:28:57.802 [Thread-89] Limiting audio preload to 0.4s.
DEBUG 2013-01-07 19:28:57.802 [Thread-89] Increasing audio density to 4.
DEBUG 2013-01-07 19:28:57.812 [Thread-90] Could not find matching colorspace - retrying with -vf scale...
DEBUG 2013-01-07 19:28:57.812 [Thread-90] Opening video filter: [scale]
DEBUG 2013-01-07 19:28:57.812 [Thread-90] Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
DEBUG 2013-01-07 19:28:57.812 [Thread-90] [swscaler @ 0129a300]using unscaled yuv420p10le -> yuv420p special converter
DEBUG 2013-01-07 19:28:57.813 [Thread-90] videocodec: libavcodec (1280x720 fourcc=3267706d [mpg2])
DEBUG 2013-01-07 19:28:57.813 [Thread-90] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2013-01-07 19:28:57.914 [Thread-90] Writing header...
DEBUG 2013-01-07 19:28:57.914 [Thread-90] INITV: 0.200, 0.158, fps: 23.976
INFO  2013-01-07 19:29:01.507 [StopPlaying Event] Stopped playing _Commie_ KC - 01 _9F4D9C67_.mkv on your Samsung AllShare
DEBUG 2013-01-07 19:29:01.508 [StopPlaying Event] The full filename of which is: H:\Movies\KC\_Commie_ KC - 01 _9F4D9C67_.mkv and the address of the renderer is: 192.168.1.5
DEBUG 2013-01-07 19:29:01.765 [Thread-90]
DEBUG 2013-01-07 19:29:01.765 [Thread-90] Flushing video frames.
DEBUG 2013-01-07 19:29:01.770 [Thread-90] Writing index...
DEBUG 2013-01-07 19:29:01.770 [Thread-90] Overhead: 1.732% (200068 / 11551356)
DEBUG 2013-01-07 19:29:01.770 [Thread-90] Writing header...
DEBUG 2013-01-07 19:29:01.770 [Thread-90] Video stream: 7389.107 kbit/s  (923638 B/s)  size: 10940650 bytes  11.845 secs  294 frames
DEBUG 2013-01-07 19:29:01.770 [Thread-90] Audio stream:  448.000 kbit/s  (55999 B/s)  size: 686336 bytes  12.256 secs
DEBUG 2013-01-07 19:29:03.767 [New I/O server worker #1-7] Setting InputStream new position to: 99,996,000,000
INFO  2013-01-07 19:29:03.767 [StartPlaying Event] Started playing _Commie_ KC - 01 _9F4D9C67_.mkv on your Samsung AllShare
DEBUG 2013-01-07 19:29:03.767 [StartPlaying Event] The full filename of which is: H:\Movies\KC\_Commie_ KC - 01 _9F4D9C67_.mkv and the address of the renderer is: 192.168.1.5
DEBUG 2013-01-07 19:29:03.783 [New I/O server worker #1-8] Setting InputStream new position to: 99,996,000,000
DEBUG 2013-01-07 19:29:03.814 [New I/O server worker #1-9] Setting InputStream new position to: 1
DEBUG 2013-01-07 19:29:04.391 [New I/O server worker #1-13] Setting InputStream new position to: 1
DEBUG 2013-01-07 19:29:11.645 [New I/O server worker #1-14] Setting InputStream new position to: 11,755,521
DEBUG 2013-01-07 19:29:13.642 [Buffered IO End Checker] Stopping process: mencoder.exe-19
INFO  2013-01-07 19:29:15.670 [StopPlaying Event] Stopped playing _Commie_ KC - 01 _9F4D9C67_.mkv on your Samsung AllShare
DEBUG 2013-01-07 19:29:15.670 [StopPlaying Event] The full filename of which is: H:\Movies\KC\_Commie_ KC - 01 _9F4D9C67_.mkv and the address of the renderer is: 192.168.1.5
INFO  2013-01-07 19:29:21.192 [New I/O server worker #1-16] Starting transcode/remux of _Commie_ KC - 01 _9F4D9C67_.mkv
DEBUG 2013-01-07 19:29:21.223 [New I/O server worker #1-16] Creating pipe \\.\pipe\mencoder1357583361223
DEBUG 2013-01-07 19:29:21.286 [Thread-91] Waiting for pipe connection \\.\pipe\mencoder1357583361223
DEBUG 2013-01-07 19:29:21.348 [mencoder.exe-20] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 "C:\Users\User1\AppData\Local\Temp\universalmediaserver\pms-avs-_Commie_ KC - 01 _9F4D9C67_.mkv.avs" -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=8 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=448:threads=8:keyint=5:vqscale=1:vqmin=2:vrc_maxrate=11000:vrc_buf_size=1835 -subdelay 20000 -ofps 24000/1001 -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o \\.\pipe\mencoder1357583361223
DEBUG 2013-01-07 19:29:21.348 [mencoder.exe-20] Reading pipe: \\.\pipe\mencoder1357583361223
DEBUG 2013-01-07 19:29:21.348 [mencoder.exe-20] Attaching thread: mencoder.exe-20
DEBUG 2013-01-07 19:29:21.364 [Thread-95] MEncoder SB44 (C) 2000-2012 MPlayer Team
DEBUG 2013-01-07 19:29:21.364 [Thread-95] Custom build by SubJunk, http://www.spirton.com
DEBUG 2013-01-07 19:29:21.379 [Thread-95] success: format: 0  data: 0x0 - 0x9a
DEBUG 2013-01-07 19:29:21.379 [Thread-95] libavformat version 54.40.100 (internal)
DEBUG 2013-01-07 19:29:23.276 [Thread-95] AVS file format detected.
DEBUG 2013-01-07 19:29:23.277 [Thread-95] VIDEO:  [YV12]  1280x720  12bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
DEBUG 2013-01-07 19:29:23.277 [Thread-95] [V] filefmt:38  fourcc:0x32315659  size:1280x720  fps:23.976  ftime:=0.0417
DEBUG 2013-01-07 19:29:23.277 [Thread-95] ==========================================================================
DEBUG 2013-01-07 19:29:23.277 [Thread-95] Opening audio decoder: [pcm] Uncompressed PCM audio decoder
DEBUG 2013-01-07 19:29:23.277 [Thread-91] Result of \\.\pipe\mencoder1357583361223 : true
DEBUG 2013-01-07 19:29:23.277 [Thread-95] AUDIO: 48000 Hz, 2 ch, floatle, 3072.0 kbit/100.00% (ratio: 384000->384000)
DEBUG 2013-01-07 19:29:23.277 [Thread-95] Selected audio codec: [pcm] afm: pcm (Uncompressed PCM)
DEBUG 2013-01-07 19:29:23.277 [Thread-95] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2013-01-07 19:29:23.277 [Thread-95] libavcodec version 54.77.101 (internal)
DEBUG 2013-01-07 19:29:23.278 [Thread-95] Opening video filter: [expand osd=1]
DEBUG 2013-01-07 19:29:23.278 [Thread-95] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
DEBUG 2013-01-07 19:29:23.279 [Thread-95] ==========================================================================
DEBUG 2013-01-07 19:29:23.279 [Thread-95] Opening video decoder: [raw] RAW Uncompressed Video
DEBUG 2013-01-07 19:29:23.279 [Thread-95] Movie-Aspect is undefined - no prescaling applied.
DEBUG 2013-01-07 19:29:23.279 [Thread-95] videocodec: libavcodec (1280x720 fourcc=3267706d [mpg2])
DEBUG 2013-01-07 19:29:23.279 [Thread-95] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2013-01-07 19:29:23.283 [Thread-95] Selected video codec: [rawyv12] vfm: raw (RAW YV12)
DEBUG 2013-01-07 19:29:23.283 [Thread-95] ==========================================================================
DEBUG 2013-01-07 19:29:23.283 [Thread-94] [ac3 @ 0114ec60]Channel layout not specified
DEBUG 2013-01-07 19:29:23.284 [Thread-94] [ac3 @ 0114ec60]No channel layout specified. The encoder will guess the layout, but it might be incorrect.
DEBUG 2013-01-07 19:29:23.284 [Thread-94] Limiting audio preload to 0.4s.
DEBUG 2013-01-07 19:29:23.284 [Thread-94] Increasing audio density to 4.
DEBUG 2013-01-07 19:29:23.438 [Thread-95] Writing header...
DEBUG 2013-01-07 19:29:23.439 [Thread-95] INITV: 0.200, 0.158, fps: 23.976
INFO  2013-01-07 19:29:27.449 [StartPlaying Event] Started playing _Commie_ KC - 01 _9F4D9C67_.mkv on your Samsung AllShare
DEBUG 2013-01-07 19:29:27.451 [StartPlaying Event] The full filename of which is: H:\Movies\KC\_Commie_ KC - 01 _9F4D9C67_.mkv and the address of the renderer is: 192.168.1.5
DEBUG 2013-01-07 19:29:28.051 [New I/O server worker #1-2] Setting InputStream new position to: 32,768
DEBUG 2013-01-07 19:29:28.120 [New I/O server worker #1-3] Setting InputStream new position to: 65,536
DEBUG 2013-01-07 19:29:28.181 [New I/O server worker #1-4] Setting InputStream new position to: 98,304
DEBUG 2013-01-07 19:29:28.253 [New I/O server worker #1-5] Setting InputStream new position to: 131,072
DEBUG 2013-01-07 19:29:28.326 [New I/O server worker #1-6] Setting InputStream new position to: 163,840
DEBUG 2013-01-07 19:29:28.390 [New I/O server worker #1-7] Setting InputStream new position to: 196,608
DEBUG 2013-01-07 19:29:28.462 [New I/O server worker #1-8] Setting InputStream new position to: 229,376
DEBUG 2013-01-07 19:29:28.532 [New I/O server worker #1-9] Setting InputStream new position to: 262,144
DEBUG 2013-01-07 19:29:28.653 [New I/O server worker #1-10] Setting InputStream new position to: 294,912
DEBUG 2013-01-07 19:29:28.734 [New I/O server worker #1-11] Setting InputStream new position to: 327,680
DEBUG 2013-01-07 19:29:28.803 [New I/O server worker #1-12] Setting InputStream new position to: 360,448
DEBUG 2013-01-07 19:29:28.874 [New I/O server worker #1-13] Setting InputStream new position to: 393,216
DEBUG 2013-01-07 19:29:28.968 [New I/O server worker #1-14] Setting InputStream new position to: 425,984
DEBUG 2013-01-07 19:29:29.031 [New I/O server worker #1-15] Setting InputStream new position to: 458,752
DEBUG 2013-01-07 19:29:29.087 [New I/O server worker #1-16] Setting InputStream new position to: 491,520
DEBUG 2013-01-07 19:29:29.164 [New I/O server worker #1-1] Setting InputStream new position to: 524,288
DEBUG 2013-01-07 19:29:29.232 [New I/O server worker #1-2] Setting InputStream new position to: 557,056
DEBUG 2013-01-07 19:29:29.289 [New I/O server worker #1-3] Setting InputStream new position to: 589,824
DEBUG 2013-01-07 19:29:29.355 [New I/O server worker #1-4] Setting InputStream new position to: 622,592
DEBUG 2013-01-07 19:29:29.417 [New I/O server worker #1-5] Setting InputStream new position to: 655,360
DEBUG 2013-01-07 19:29:29.491 [New I/O server worker #1-6] Setting InputStream new position to: 688,128
DEBUG 2013-01-07 19:29:29.552 [New I/O server worker #1-7] Setting InputStream new position to: 720,896
DEBUG 2013-01-07 19:29:29.607 [New I/O server worker #1-8] Setting InputStream new position to: 753,664
DEBUG 2013-01-07 19:29:29.678 [New I/O server worker #1-9] Setting InputStream new position to: 786,432
DEBUG 2013-01-07 19:29:29.732 [New I/O server worker #1-10] Setting InputStream new position to: 819,200
DEBUG 2013-01-07 19:29:29.795 [New I/O server worker #1-11] Setting InputStream new position to: 851,968
DEBUG 2013-01-07 19:29:29.867 [New I/O server worker #1-12] Setting InputStream new position to: 884,736
DEBUG 2013-01-07 19:29:29.935 [New I/O server worker #1-13] Setting InputStream new position to: 917,504
DEBUG 2013-01-07 19:29:30.005 [New I/O server worker #1-14] Setting InputStream new position to: 950,272
DEBUG 2013-01-07 19:29:30.070 [New I/O server worker #1-15] Setting InputStream new position to: 983,040
DEBUG 2013-01-07 19:29:30.130 [New I/O server worker #1-16] Setting InputStream new position to: 1,015,808
DEBUG 2013-01-07 19:29:30.244 [New I/O server worker #1-2] Setting InputStream new position to: 99,996,000,000
DEBUG 2013-01-07 19:29:30.271 [New I/O server worker #1-3] Setting InputStream new position to: 99,996,000,000
DEBUG 2013-01-07 19:29:35.307 [New I/O server worker #1-4] Setting InputStream new position to: 1
DEBUG 2013-01-07 19:29:35.509 [New I/O server worker #1-8] Setting InputStream new position to: 1
INFO  2013-01-07 19:29:49.288 [StopPlaying Event] Stopped playing _Commie_ KC - 01 _9F4D9C67_.mkv on your Samsung AllShare
DEBUG 2013-01-07 19:29:49.288 [StopPlaying Event] The full filename of which is: H:\Movies\KC\_Commie_ KC - 01 _9F4D9C67_.mkv and the address of the renderer is: 192.168.1.5
V4mP123
Re: Missing Renderers in Transcode Folder + CPU thread Probl
Post by V4mP123 »
Sorry Subjunk for overlooking your PM.
I only looked on this thread without logging in.
Summary quick test of V2.2.5:
1) Renderers are present again in Transcode-folder.
2) Quick test of a file that crashed with 8threads: did run 10 Minutes without crashing (last time it crashed after 11 seconds).
PS: If I dont answer quick enough.. just post a reply here ... I'll try to logon more frequently ;-)
Great, so in other words the problem is fixed? Yay!
V4mP123
Post by V4mP123 »
As said before it was just a quick 10 minute Test.
If I encounter the problem again I'll post it here. But think of it as fixed so far.
