Subtittles cut off even with over scanning compensation
I may be wrong here, but I was under the impression that the over scanning compensation feature would also make the subs stay with in the video. I know i can play with the sub margin, and bring up the subs, but that will not keep them from getting cutoff length wise. Also, is there anyway to set up UMS to only use the over scanning feature on my 360? My 360 is the only thing connected to a tv that I can not control the over scanning on.
Re: Subtittles cut off even with over scanning compensation
We used to have that feature but it must have been lost, I'll write it againtMH wrote:I may be wrong here, but I was under the impression that the over scanning compensation feature would also make the subs stay with in the video. I know i can play with the sub margin, and bring up the subs, but that will not keep them from getting cutoff length wise.
There isn't, but I can introduce that feature. I'll add that to the to-do list tootMH wrote:Also, is there anyway to set up UMS to only use the over scanning feature on my 360? My 360 is the only thing connected to a tv that I can not control the over scanning on.
I just looked and the code is still in there, so I will need your debug.log to see why it isn't working
INFO 2012-06-19 00:40:42.476 [New I/O server worker #1-5] Starting transcode/remux of [A-Destiny]_Kingdom_-_01_(848x480_h264_AAC)_[3EFF4799].mkv
INFO 2012-06-19 00:40:42.554 [New I/O server worker #1-5] Setting video resolution to: 0x0, the maximum your renderer supports
INFO 2012-06-19 00:40:42.554 [New I/O server worker #1-5] Setting video resolution to: 0x0, to fit your overscan compensation
DEBUG 2012-06-19 00:40:42.554 [New I/O server worker #1-5] Creating pipe \\.\pipe\mencoder1340080842554
DEBUG 2012-06-19 00:40:42.648 [Thread-13] Waiting for pipe connection \\.\pipe\mencoder1340080842554
DEBUG 2012-06-19 00:40:42.710 [mencoder.exe-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 -quiet "C:\sysreset\sysreset\download\01 New and Unsorted Video Files\[A-Destiny]_Kingdom_-_01_(848x480_h264_AAC)_[3EFF4799].mkv" -quiet -quiet -oac lavc -of lavf -lavfopts format=asf -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 2 -lavdopts debug=0:threads=2 -lavcopts autoaspect=1:vcodec=wmv2:acodec=wmav2:abitrate=448:threads=1:keyint=5:vqscale=1:vqmin=2:vrc_maxrate=14000:vrc_buf_size=1835 -ass -ass-force-style MarginV=0 -noflip-hebrew -fontconfig -subcp cp1252 -quiet -quiet -sid 0 -quiet -quiet -ofps 24000/1001 -quiet -quiet -vf softskip,expand=-192:-80,scale=1040:560,harddup -lavdopts fast -mc 0 -noskip -af lavcresample=44100 -srate 44100 -o \\.\pipe\mencoder1340080842554
DEBUG 2012-06-19 00:40:42.710 [mencoder.exe-1] Reading pipe: \\.\pipe\mencoder1340080842554
DEBUG 2012-06-19 00:40:42.726 [mencoder.exe-1] Attaching thread: mencoder.exe-1
DEBUG 2012-06-19 00:40:43.256 [Thread-17] MEncoder SB34 (C) 2000-2012 MPlayer Team
DEBUG 2012-06-19 00:40:43.256 [Thread-17] Custom build by SubJunk, http://www.spirton.com
DEBUG 2012-06-19 00:40:43.256 [Thread-17] success: format: 0 data: 0x0 - 0x126029e3
DEBUG 2012-06-19 00:40:43.256 [Thread-17] libavformat version 54.6.100 (internal)
DEBUG 2012-06-19 00:40:43.256 [Thread-17] libavformat file format detected.
DEBUG 2012-06-19 00:40:43.400 [Thread-16] [matroska,webm @ 010cb520]max_analyze_duration 5000000 reached at 5019000
DEBUG 2012-06-19 00:40:43.400 [Thread-16] [matroska,webm @ 010cb520]Could not find codec parameters (Attachment: none)
DEBUG 2012-06-19 00:40:43.400 [Thread-17] [lavf] stream 0: video (h264), -vid 0
DEBUG 2012-06-19 00:40:43.400 [Thread-17] [lavf] stream 1: audio (aac), -aid 0
DEBUG 2012-06-19 00:40:43.400 [Thread-17] [lavf] stream 2: subtitle (ass), -sid 0
DEBUG 2012-06-19 00:40:43.403 [Thread-17] VIDEO: [H264] 848x480 0bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s)
DEBUG 2012-06-19 00:40:43.405 [Thread-17] [V] filefmt:44 fourcc:0x34363248 size:848x480 fps:23.976 ftime:=0.0417
DEBUG 2012-06-19 00:40:43.405 [Thread-17] ==========================================================================
DEBUG 2012-06-19 00:40:43.406 [Thread-17] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2012-06-19 00:40:43.407 [Thread-17] libavcodec version 54.23.100 (internal)
DEBUG 2012-06-19 00:40:43.408 [Thread-17] AUDIO: 48000 Hz, 2 ch, s16le, 0.0 kbit/0.00% (ratio: 0->192000)
DEBUG 2012-06-19 00:40:43.408 [Thread-17] Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
DEBUG 2012-06-19 00:40:43.408 [Thread-17] ==========================================================================
DEBUG 2012-06-19 00:40:43.408 [Thread-13] Result of \\.\pipe\mencoder1340080842554 : true
DEBUG 2012-06-19 00:40:43.408 [Thread-16] ** MUXER_LAVF *****************************************************************
DEBUG 2012-06-19 00:40:43.408 [Thread-17] OK, exit.
DEBUG 2012-06-19 00:40:43.408 [Thread-16] REMEMBER: MEncoder's libavformat muxing is presently broken and can generate
DEBUG 2012-06-19 00:40:43.408 [Thread-16] INCORRECT files in the presence of B-frames. Moreover, due to bugs MPlayer
DEBUG 2012-06-19 00:40:43.408 [Thread-16] will play these INCORRECT files as if nothing were wrong!
DEBUG 2012-06-19 00:40:43.408 [Thread-16] *******************************************************************************
DEBUG 2012-06-19 00:40:43.418 [Thread-17] Opening video filter: [ass auto=1]
DEBUG 2012-06-19 00:40:43.418 [Thread-17] [ass] auto-open
DEBUG 2012-06-19 00:40:43.421 [Thread-17] Opening video filter: [harddup]
DEBUG 2012-06-19 00:40:43.421 [Thread-17] Opening video filter: [scale w=1040 h=560]
DEBUG 2012-06-19 00:40:43.421 [Thread-17] Opening video filter: [expand w=-192 h=-80]
DEBUG 2012-06-19 00:40:43.421 [Thread-17] Expand: -192 x -80, -1 ; -1, osd: 0, aspect: 0.000000, round: 1
DEBUG 2012-06-19 00:40:43.421 [Thread-17] Opening video filter: [softskip]
DEBUG 2012-06-19 00:40:43.470 [Thread-17] ==========================================================================
DEBUG 2012-06-19 00:40:43.471 [Thread-17] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2012-06-19 00:40:43.473 [Thread-17] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2012-06-19 00:40:43.473 [Thread-17] ==========================================================================
DEBUG 2012-06-19 00:40:43.485 [Thread-16] Unsupported PixelFormat 61
DEBUG 2012-06-19 00:40:43.486 [Thread-16] Unsupported PixelFormat 53
DEBUG 2012-06-19 00:40:43.486 [Thread-16] Unsupported PixelFormat 81
DEBUG 2012-06-19 00:40:43.489 [Thread-17] Movie-Aspect is 1.77:1 - prescaling to correct movie aspect.
DEBUG 2012-06-19 00:40:43.489 [Thread-17] [swscaler @ 0121f240]using unscaled yuv420p -> yuv420p special converter
DEBUG 2012-06-19 00:40:43.489 [Thread-17] videocodec: libavcodec (1040x560 fourcc=32564d57 [WMV2])
DEBUG 2012-06-19 00:40:43.489 [Thread-17] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2012-06-19 00:40:43.503 [Thread-17] VIDEO CODEC ID: 19
DEBUG 2012-06-19 00:40:43.503 [Thread-17] AUDIO CODEC ID: 15008, TAG: 0
DEBUG 2012-06-19 00:40:43.503 [Thread-17] Writing header...
DEBUG 2012-06-19 00:40:43.503 [Thread-16] [asf @ 010cb520]Codec for stream 0 does not use global headers but container format requires global headers
DEBUG 2012-06-19 00:40:43.503 [Thread-16] [asf @ 010cb520]Codec for stream 1 does not use global headers but container format requires global headers
DEBUG 2012-06-19 00:40:43.518 [Thread-17] [wmv2 @ 010ec8c0]warning, clipping 1 dct coefficients to -255..255
DEBUG 2012-06-19 00:40:43.532 [Thread-17] [wmv2 @ 010ec8c0]warning, clipping 1 dct coefficients to -255..255
DEBUG 2012-06-19 00:40:46.146 [Thread-17] [wmv2 @ 010ec8c0]warning, clipping 1 dct coefficients to -255..255
etc
