Something not right in UMS initial file structure - weird prblm
goldfinger
Post by goldfinger »
Version 5.2.3 of the UMS :)
I use the UMS in a linux setting and it works well with my TV set.
I have a QNAP which has its own DLNA server (serves here for control: TwonkyMedia)
On my iPad something works weird:
I have two DLNA client apps: Fusion Stream and PlayerXtreme
PlayerXstreme is only occasionally able to see the filestructure in the DLNA on UMS. All other combinations work (and that sucks).
So: Fusion Stream sees the file structure on both DLNA servers.
PlayerXtreme sees the file structure on TwonkyMedia, but not on UMS.
When Fusion Stream connects I get only two lines:
01:01:08 INFO No IP filter specified, access granted to /192.168.0.73
01:02:17 INFO Checking shared folder: /var/media
When PLayerXtreme connects I get only the first.
In both cases UMS recognizes the iPad as renderer (I added the PLayerXtreme header oc)
OK - I see ... the debug.log file.... makes sense :)
The iPad renderer is located at 192.168.0.73
Sincerely,
Dr. Karsten Jeppesen
debug.tar.gz
(13.28 KiB) Downloaded 463 times
