Media server error
Media server error
On my playstation I can see photos and play music using UMS but whenever I try to play videos I get the same error.
Media server error
a network error has occured
(000001F4)
I'm using linux Mint 14
Media server error
(000001F4)
- (12.05 KiB) Downloaded 567 times
Re: Media server error
I may be incorrect, and please let me know if I am, but if I read correctly, you don't have ffmpeg installed. And possibly mplayer if I read in there correctly. I would install those first. Let's see, you're on a Debian based system... so
should do the trick.
If it says it can't find either one, do
then
If it can't find the correct package, then you may need to enable your multiverse repo. I haven't used Linux Mint since it was number 11, so I don't remember how I enabled the multiverse.
sudo apt-get install ffmpeg mplayer
sudo apt-cache search ffmpeg
sudo apt-cache search mplayer
Thank you so much. No it did not work from the terminal commands, but I was able to find "ffmpeg" in the software center.
There was a difference when I tried right after of a new error "the Media cannot be played" but I found all I had to download "mencoder"
I also then had to install "mencoder" through the software center.
Works great now!keyint=5:vqscale=1:vqmin=2
