UMS won't detect PS3 sometimes
Weird problem with UMS. Ususally everthing is fine and the PS3 en my TV are detected, but not always. If I reboot my PC UMS won't detect my PS3 anymore, it just states: "no renderes detected". The only thing that solves this is reinstalling java, something that is very time consuming (slow booting). After reinstalling everything is fine again, but if the PC is rebooted it won't work anymore.
So I was wondering if anyone knew a better solution to this very annoying problem?
Re: UMS won't detect PS3 sometimes
Can you post a debug log?
You mean when it does not locate a renderer? I first need to wait for the bug to unfold again. But when it does I will post it.
- Optimus_prime
To assist the guy's in getting your problem looked at follow this post.
You need to include the debug log, including the problem that's occurring.
viewtopic.php?f=9&t=556
Oké server didn't recognize renderers. So here is the debug log.
- (11.34 KiB) Downloaded 541 times
It can happen if the PS3 has been on for a while, I think it is a bug in the PS3 because I tried to track down the bug but it happened even with very old versions of PMS (like from 3 years ago)
No it only happens if I reboot my PC. UMS will start, but there is something wrong in java, because if I reinstall java everything works fine again. In the debug I turned the PS3 on after UMS was started. Also normally it recognizes my TV and my PS3, but it's either none or both. I think the bug is in java or there could be something wrong with the configuration on my computer.
Edit: Hmm, I think I found the problem. Turns out that if I disable the windows service the PS3 is found once again! Will check to see if it stays this way and keep you guys informed.
