Samsung UE65JS8500 / UE65JS8502
vigur
Post by vigur »
I have trouble playing some movies on my TV from UMS, which could be played on TV from USB stick. I have a wired connection with 1GB Lan around home. My current guess that it happens only to movies that are 1080p quality and close to 10GB in size, but it might be also some renderer config problem.
Example of codec parameters from movie that can't be played from UMS, but plays connection USB stick to TV:
Codec: H264 - MPEG-4 AVC (part 10) (avc1)
Resolution: 1920x1058
Display resolution: 1920x1036
Frame rate: 23.976215
Decoded format: Planar 4:2:0 YUV
Codec: DTS Audio (dts )
Channels: 3F2R/LFE
Sample rate: 48000 Hz
Bitrate: 768 kb/s
File container: mkv
File size 8.43 GB
Any advice on renderer config change ?
Best regards,
Aleksei
