streaming suddenly started stopping after 1-2 minutes
For some strange reason, my streaming setup from PC UMS -> Samsung TV stopped working.
The symptoms are stop of streaming 1-2 minutes after starting it, also, most video files are showing up as dated 1-Jan-2000 in the interface (could be unrelated).
I've attached trace logs.
This has worked fine for several years but now suddenly, doesn't want to work at all. Video files are working locally.
- (51.95 KiB) Downloaded 624 times
Re: streaming suddenly started stopping after 1-2 minutes
We saw the same thing last night.. walking dead stopped on our ps4, as well as something else I forget. I restarted the server to see if there was a memory leak, and nothing changed... popped in here just now to see if this was a known issue.
EDIT: The problem seems to be with MKV format playback... I converted the mkv to mp4, and it plays back fine. Last time I recall this happening, one of the popular encoder programs updated and changed formats slightly causing the issue.
The file in question specifically for me was The.Walking.Dead.S06E06.720p.HDTV.x264-0SEC
No solution to this issue? I just ran into it again tonight with
The.Walking.Dead.S06E07.720p.HDTV.x264-0SEC
