Solved: Update: run as administrator
For some reason I can't update to the new version that was released today. It tells me an update is available but I need to run UMS as an administrator in order to be able to update.
I've double-checked, the account I'm logged into for windows 8.1 has administrator rights.
What am I missing?
What am I missing?
Re: Update: run as administrator
just right click on the updater and click run as administrator windows security has always been overly done i run into this issue as well
Thank you very much, that indeed did the trick
Re: Solved: Update: run as administrator
Start>all programs>right click on UMS>properties>compatibility>check run as an administrator
