Stream from analog video capture card
Hi @ all!
I want to stream an analog video signal which is grabbed by a Hauppauge ImpactVCB. Is it possible to stream this?
I found a similar thread regarding a TV card but I think this to different.
Thx for any hints![Smile :)](./images/smilies/icon_e_smile.gif)
Thx for any hints
Re: Stream from analog video capture card
Interesting, I would probably start by making sure the analog video is captured by VLC and transcode/remux it to something your renderer would accept streamed as is to avoid a 2nd trnscoding by UMS, and then that stream be announced via the web streams capability of UMS.
Probably I overcomplicated it![Smile :-)](./images/smilies/icon_e_smile.gif)
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
If you're on Windows and the card is directshow-compliant, you can try the jumpy capture script. But first see if it shows up as a directshow device by opening a command window in the UMS win32 folder and running ffmpeg:nopilopi wrote:I want to stream an analog video signal which is grabbed by a Hauppauge ImpactVCB. Is it possible to stream this?
ffmpeg -list_devices true -f dshow -i dummy
