Subtitles issues
louis54000
Subtitles issues
Post by louis54000 »
I have issues with subtitles (external srt):
If I choose FFMpeg, subtitles show up perfectly for a few minutes, then disappear, and reappear. So half of the text is not showing up.
If I choose MEncoder, they show up all the time, but twice (see attached image)
I'm using UMS 5.3.0 on Windows 10, fresh install (using "Sony Bravia EX" renderer)
Here is the log http://pastebin.com/XKBPFmSg
Any ideas how to fix this ? Thank you,
Louis.
valib
Re: Subtitles issues
Post by valib »
Please can you try the latest UMS SNAPSHOT? You can download it at http://universalmediaserver-ci.hopto.or ... APSHOT.exe
louis54000
Hi, sorry for the late answer, but I get an error 404 with you link. I'm going to try with UMS 6 beta.
The beta won't do it, the changes he did isn't in there.
I've built and uploaded the latest snapshot here.
squadjot
Post by squadjot »
With mencoder, try disable "Use ASS/SSA subtitles styling"
louis54000
So I tried disabling "Use ASS/SSA subtitles styling" and it solved part of the problem : I don't have twice the subtitles anymore, but the text size changes every 500ms or so (once normal size then bigger, and normal again...).
I tried the snapshot, I didn't change anything either.
Here is the debug log with the snapshot http://pastebin.com/qrgTZcyU
squadjot
Post by squadjot »
louis54000 wrote:(once normal size then bigger, and normal again...).
Ok, that's weird.. i have no clue why it does that. Sounds like a bug
Byt the way..to the developers: the double subtitles / using ASS/SSA subtitles is might somehting you should have a look at. It's a bug that's been there forever.
valib
Post by valib »
louis54000 wrote:So I tried disabling "Use ASS/SSA subtitles styling" and it solved part of the problem : I don't have twice the subtitles anymore, but the text size changes every 500ms or so (once normal size then bigger, and normal again...).
Please follow the forum rules and post here the packed trace log files which contains also your setup and other relevant files. You can simply add attachments here when you write a post a reply. It is above the editing area.
louis54000
There you go. Thanks.
(104.25 KiB) Downloaded 621 times
