Version 2.3.0 is released
Post by SubJunk » Mon Jan 28, 2013 10:54 am
General:
This release adds audio selection to FFmpeg, improved MKV/MP4 support, makes transcoding faster and more!
Changes since 2.2.6:
  • General:
    • FFmpeg supports audio selection
    • Improved MKV/MP4 support on PS3
    • Fixed rare bug where files stop half way through
    • Support streaming mp4 to WD TV Live
    • Added initial support for Vizio Smart TVs
    • Fixed playback on unknown renderers
    • Fixed several FFmpeg-related bugs
    • Improved support for videos whose containers change aspect ratios
    • Tried to fix headless mode detection on Ubuntu
    • Fixed various bugs
  • External Components:
    • Updated FFmpeg for Windows to SB5, which:
      • Improves AC-3 audio buffering
      • Fixes memory leaks
      • Fixes a bug which detected transport streams as finished when they weren't
      • Improved MPEG-PS encoding
      • Made error codes more meaningful
      • Improves Matroska (MKV) support
      • Improves threading
      • Optimized AC-3 decoding
    • Updated InterFrame to 2.4.0, which:
      • Improves scene-change detection
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
Cameron Spiers for building the OS X version
Phonism
Re: Version 2.3.0 is released
Post by Phonism » Tue Jan 29, 2013 2:09 am
Thank you for making this awesome software even better! :D
UMS 5.3.0 - Java 8 update 60 - Windows 10 Pro 64bit
Intel Core i7-3770 - 8GB RAM
PS3 Slim 120GB
PS4
Mrhyd
Post by Mrhyd » Wed Jan 30, 2013 6:00 pm
Great !!
Installed successfully without any issues. However, channel and other plug-ins are not working. I guess i have to report them in diff section.
Raker13
Post by Raker13 » Sun Feb 03, 2013 9:36 am
Thumbs up! Thanks
Phonism
Post by Phonism » Tue Feb 05, 2013 5:32 am
2.3.0 has been working flawlessly since release - I'm using it pretty much straight out of the box, switching between MEncoder and tsMuxeR :D
PS3 Slim 120GB
PS4
