Installing UMS on an Rpi 2
I was wondering if it was possible to set up UMS on the Raspberry Pi 2, I wouldn't mind overclocking it a bit if that meant less stuttering for example.
Thanks in advance, wevans59
Re: Installing UMS on an Rpi 2
Usually those SoCs aren't powerful enough for transcoding (unless you have custom drivers taking advantage of specific hardware assistance), just enough for serving and probably remuxing and maybe transcoding audio only.wevans59 wrote:I was wondering if it was possible to set up UMS on the Raspberry Pi 2, I wouldn't mind overclocking it a bit if that meant less stuttering for example.
Did you try minidlna?
