<SOLVED> Please delete posting. Bravia and Win 10
I have read the how to request support link and will follow instructions if after describing issue there appears to be a need for trace log.
Equipment: Sony KDL-52Z5100 Bravia. Dell Inspiron 12g RAM, 1tb HD, i5 CPU. Both wire connected to home network.
I installed UMS after issues with WMP 12 and Plex. UMS is awesome by the way. Instantly worked with default settings. Opened XBR and was able to access all folders on PC and external drive, very cool. Was able to see and view pics and play videos of varying format.
Subsequent efforts to play videos are sporadic at best. I can still view pics everytime without issue. Videos of all formats are now flaky. On XBR as I go through the folders I see videos then the various folder names representing the movies. If I select a folder I sometimes see a folder named #--Transcode--# and then selecting that folder shows the prettified video name and selecting that folder shows "There are no items to display". Other times my videos show and basically have no issues (sometimes video out of sync with audio).
I've made zero changes to firewalls or UMS software or anything to explain this. The renderer associated with TV is Bravia 5500.
Help? Thank you in advance.
Jim
Jim
Re: Bravia and Win 10
We need the debug files for those movies that won't play, so we can figure out what the reason is.
