Subtitle position
skovo
Subtitle position
Post by skovo »
I´ve been trying to find a topic about this "problem" on the forum, but I wasn´t, so setting up this topic. If I overlooked it, I apologize :)
Is there an option to change subtitles positioning in the video? I was trying some of the settings available for subtitles, but didn´t find this option.
The issue is, that subtitles are displayed always only within the video.
If you play a 16:9 format video, everything is ok, the subtitles are at the bottom and in reasonable size.
However most movies are in 21:9/2.35:1 aspect ratio, where you have black borders at the top/bottom of the screen and in such case, since the subtitles are displayed within the video, they are smaller size and honestly, I don´t like them displayed within video when playing 21:9/2.35:1 aspect ratio video files.
I would want to have them at the bottom all the time (use the black border for subtitles, as it´s less disturbing when watching a movie). Is there a way to set this up ? If not, are there any plans to include this feature in some future release?
squadjot
Re: Subtitle position
Post by squadjot »
Try switch to mencoder, does that help?
FFMPEG seems to put subtitles inside the video area, whereas Mencoder puts the subtitles in the "outside" area (in the black frame)
I think the subtitles should always be in the black area if possible.
skovo
Post by skovo »
Ok, I´ve figured out how to switch to MEncoder that and it fixed the subtitle positioning, however with MEncoder there are issues with video playback.
If you pause the video or FW/RW and then resume playback, it takes quite some time to resume and the audio/video are de-synced
Other issue I found is, that by some HEVC x265 video files I play, the top/bottom black borders are not black, but green :)
Tried latest 5.4 stable version as well as 6.0b version. Am using W10 and Panasonic Viera Plasma TV
Madoka
Post by Madoka »
That's weird as both FFmpeg and MEncoder put the subtitles within the video for me, even for 2.35:1 movies. I think this should be a user configurable feature.
skovo
Post by skovo »
I just tried 6.0.0-b2 and with FFmpeg the subtitles are displayed now always at the bottom of the screen :)
squadjot
Post by squadjot »
skovo wrote:I just tried 6.0.0-b2 and with FFmpeg the subtitles are displayed now always at the bottom of the screen :)
Yes ;)
valib
Post by valib »
It is also implemented in the last release 5.5.0
