Sony KDL50W805B sound issues
Heba
Post by Heba »
Hello Guys,
I got a major problem with the sound on my Sony and I don´t know how to solve as.
When I play certain videos on my TV the sound doesn´t work properly. It´s a sratch noise every second with a pause every second:
sratch pause sratch pause ...... and so on.
The files are .avi files with:
Bitrate: 192
Chanels: 2
Rate: 48 kHz
When I convert them to .mkv with:
Bitrate: 64
Chanels: 2
Rate: 48 kHz
everything is ok.
It´s the same effect when I stream it with UMS, WMP or directly with an usb stick.
If I use "mencoder" in the transcode folder it works even with the .avi O.o
Is there any option to solve the problem that I don´t need to go through the #transcode folder?
Thanks!
