No sound on some files in new version
salsolo
Post by salsolo »
Hi.
Time for me to ask for help :)
I have for the last couple of versions had an issue of no sound in some of my files - primarily iso and avi. I haven't been able to find a comon nominator between my files as I have plenty of other iso and avi's working fine.
The kicker is that it has been working with older versions but has been broken the last 3 versions.
I have tried to change all different kind of settings but no change with sound at all.
I was hoping that 2.3.0 would fix it but I just did a completely clean install of it and the issue is still there.
Platform is Windows 2012 and nothing else is on it beside what UMS needs.
I have attached the debug files and I hope someone can give me a clue of what to fix :)
(78.57 KiB) Downloaded 768 times
Re: No sound on some files in new version
Hi salsolo :) Please attach a debug log for the last version of UMS that did not have the bug :)
salsolo
Post by salsolo »
I'll see if I can figure out which version it was :)
I will be back.
salsolo
Post by salsolo »
Got it!! :)
Version 2.2.3 works ..I get sound on all my files. Debug log has been attached.
ums_dbg_2.2.3.zip
(67.57 KiB) Downloaded 1032 times
John Klein
Post by John Klein »
I switched from PMS to UMS and have this exact same issue with 2.4.2.. This happens on random ISOs and I have windows 7..
What's the status?
kuroukage
Post by kuroukage »
Update to 2.5.0 and see if it fixes your issues.
黒影
John Klein
Nope.. Still doesn't work. It did work with PMS.
Attached log with some privacy edits. (Hopefully I hit them all)
debug.log
(951.35 KiB) Downloaded 1076 times
Hmm strange, is it still happening in 2.6.0?
John Klein
I currently have both the latest version of PMS and UMS installed.. PMS 1.72.0 can play all my ISOs without issues.. UMS 2.6.0 has no audio to a large percent of them..
Does this version make any difference? http://www.spirton.com/uploads/UMS/UMS-JohnKlein.exe
