Can i stop certain devices seeing UMS?
Hi all first off thanks for this great software.
Now as in subject can I configure UMS so that certain devices such as Xbox One etc cannot see it when I run it?
Re: Can i stop certain devices seeing UMS?
Ok sorry for the noobish question I think I have it sorted by using ip whitelist.
Now how can I stop it playing the next video in a folder when the current video finishes?
That's usually a function of your player/renderer, not the UMS server.CapricornDog wrote:Ok sorry for the noobish question I think I have it sorted by using ip whitelist.
Ok thanks for your reply i'll look into my tv settings.
Quick question, there's no tooltip for the ip filter whitelist no example, doesn't it take multiple ip or just 1 ?
do i seperate them with a comma ?
Win 10 64bits
Qnap TS-212 2x3TB WD Red
Sony Bravia MN (my own conf)
Hi HT1,
I separated them by using ;
I don't know if using a comma only will do the trick , but I've whitelisted 3 IP's this way and this definitely works.
Greetsssssssss Snakebyte
There a whole thread about this feature: viewtopic.php?f=3&t=2266
yep i read that thread, still had questions.Wolfgan wrote:There a whole thread about this feature: viewtopic.php?f=3&t=2266
hi Snakebyte, do you know if the whitelist mode blocks other non listed ip's or is it just to setup a root folder for those listed ?snakebyte wrote:Hi HT1,
thanks for the info guys
Win 10 64bits
