Possible solution to the 20 min limit time on PS4?
I found out the other day that there was a Plex app for the PS4. I already had tried Plex before and I had exactly the same problem I had with all the other servers: connection drop out after a while. But I decided to give it a try and now it seems to work propperly! I finally were able to watch a movie entirely using the Plex app, but also if I use the PS4 media player instead the Plex app, everything works fine now. I can't explain why, but maybe there is someone here who is willing to investigate and cast some light onto this. I suspect that if I try the UMS again, it will work now. I will let you know when I try
