here a jumpy log error for gensis
nickhere
Post by nickhere »
wont list files
(657.27 KiB) Downloaded 727 times
infidel
Re: here a jumpy log error for gensis
Post by infidel »
nickhere wrote:wont list files
This seems to crept in recently (confirmed in genesis v5.1.4, but the previous version I had, v4.0.0 dating back to last time you asked, is ok). I'll fix it in jumpy-xbmc, but first need to look into it further. It's possible to work around the immediate issue in the latest version by adding 'import xbmc' to the top of addons\plugin.video.genesis\default.py:
import xbmc
import urlparse,sys
params = dict(urlparse.parse_qsl(sys.argv[2].replace('?','')))
but I still don't seem to get any actual sources to list for shows. Will post if I find anything, but in the meantime try rolling back.
nickhere
Post by nickhere »
will do.
I am just getting back into Kodi and UMS.
Just thought I let you know.
infidel
Post by infidel »
All fixed, I think. Try the new jumpy-0.3.9-dev-160122 version in the dev builds.
NOTE: some sources may have issues if you're not using UMS 5.4.0+ due to a fix having to do with setting http headers in ffmpeg.
nickhere
Post by nickhere »
i need to find out why ums not showing up on my tv dlna first
