XBox 360 doesn't See UMS but it can see PMS
cmonster
Post by cmonster »
Hey guys
I've been running PMS successfully for a long time (up to the last release v71). Now when I run UMS, my XBox doesn't see it yet UMS sees the XBox. I've tried from two different computers (both Windows 7(x64)) and neither is seen by the XBox but UMS sees it.
When I close down UMS and run PMS, everything is normal. I've check the configuration in UMS and it matches my old PMS settings.
Any suggestions?
Re: XBox 360 doesn't See UMS but it can see PMS
Hi cmonster, welcome to the forum :)
Are you trying to run them at the same time? They will conflict with eachother. I suggest restarting your computer to make sure there are no PMS processes running, then run UMS.
Let us know if that works for you.
cmonster
Post by cmonster »
Hey. I rebooted the each computer, no change. I rebooted the Xbox each time, no change. I even turned off all network security, nothing. Each computer sees the Xbox and other renderers but the XBox is still blind.
cmonster
Post by cmonster »
Oh yeah, I can still run build 71 without a problem.
PMing for more troubleshooting
Secate
Post by Secate »
Same deal here, UMS 1.0 doesn't show up at all on the 360.
If you would like me to do any troubleshooting, feel free to PM me.
cmonster
Post by cmonster »
Secate wrote:Same deal here, UMS 1.0 doesn't show up at all on the 360.
I hate to say it but I'm glad I wasn't the only one having this problem. I was thinking that I was just being stupid. :mrgreen:
Glimmer
Post by Glimmer »
Nah it's not just you. I had the same problem last night. I had to download and reinstall build 71 for the 360.
This is my top priority and will be fixed very soon :)
cmonster
Post by cmonster »
SubJunk wrote:This is my top priority and will be fixed very soon :)
We weren't worried, we knew you were working on getting it straightened out. It's all good... :D
