UMS 6.0.0, El Capitan requires Java 6?
quick_dry
Post by quick_dry »
I just ran the new release 6.0.0 and on El Capitan it complains that I need Java 6 SE, is this a bug or correct behaviour? Java 8 is the version that the windows release requires.
Re: UMS 6.0.0, El Capitan requires Java 6?
That must be a bug, we have dropped Java 6 support some versions ago. Java 7 or Java 8 should work.
Optimus_prime
Post by Optimus_prime »
Doesn't sound right at all. Appbundler (which builds the .app and the launcher) is built with Java 7 for maximum comparability for Java 7 and 8. It only launches for these versions (7 and 8) and apple stopped bundling java 6 with OS X some time ago.
If you can attach a screen shot of the error its giving it would be great
FineWine
Post by FineWine »
I too have just installed the latest version of UMS and are having problems to do with Java on Mac OS10.11.3
Completely uninstalled UMS
I then completely uninstalled ALL VERSIONS of Java.
I then installed the latest Java Version 8 Update 73
Installed UMS version 6 but it complained it needed Java 6SE
I uninstalled UMS again
I then installed OS X 2015-001 which installs the legacy Java 6 runtime for OS X 10.11 El Capitan
Now the error message is "The application “Universal Media Server.app” can’t be opened"
I then uninstalled UMS version 6 and installed UMS 5.2.2 and all works fine.
So there is a problem with UMS version 6
bobtoubman
Post by bobtoubman »
I am new to UMS and tried to download java 8 and ams 6
both seem to download but when i try to open ums nothing happens
am i missing something? or do i have to do something to open ums after downloading?
i use OS X el capitan latest version
thanks for your help
