# Transcode # - Some questions
I just install UMS last week on my iMac. My tv is a Sony Bravia KDL-47W805A.
Why Some of the movies doesn't appear in the folder # Transcode # ? They are in my library but not in this folder.
At the begining in the # Transcode # folder i could choose the decoder (FFmpeg, MSencoder, ...) for the video if needed but now only audio
Where is the Problem ? I probably change something but iI don't know what.
Thak you
Thak you
- image.jpg (168.53 KiB) Viewed 6234 times
- ums_dbg 2.zip
- (214.83 KiB) Downloaded 442 times
Re: # Transcode # - Some questions
I don't understand what are you looking for? In the TRANSCODE folder there are sub-folders for each video from your root folder and inside those sub-folders there are all combinations of transcode engines, audios and subtitles who can exist for that particular video. So you can try which combination is working for you.
EDIT: in your ums_dbg 2.zip you provided is missing the most important part. The debug.log.
Ok. I Will try.
Thank you
Thank you
