UMS just "stopped working"
Hey all. (thanks for reading).
(if necessary). My Architecture.
"Server BOX"
X/Ubuntu.
Trusty 14.04.03. (no "exotic"/esoteric configurations).
Kernel: Linux Dawg 4.1.0-040100-generic #201510261105 SMP Mon Oct 26 11:18:18 UTC 2015 i686 i686 i686 GNU/Linux
("Wily allows backwards compat to Trusty for 4.2).
Linksys WRT54GL (uusing dd-wrt): Firmware: DD-WRT v24-sp2 (10/10/09) std
---Set with "Gateway" credentials as per DD-WRT.
Renderer LG TV 42 LS5700 LG T.V.
root@Dawg:~# java -version
java version "1.8.0_72"
Java(TM) SE Runtime Environment (build 1.8.0_72-b15)
Java HotSpot(TM) Server VM (build 25.72-b15, mixed mode)
Not sure what is up. For whatever reason, UMS just "Stopped working". The only changes I've (remembered) that I made were.
I downloaded UMS v6.0 it never worked. Thus it might??????? Have killed 5.5??? I also installed and removed other DLNA systems ("MiniDLNA" ETC, But my LG was having no problems with it, ti recognized both UMS and MiniDLNA (minidlna is gone now).
(as you know there's no "Install" on a Linux Box. I'm still running 5.5 (from command line with GUI Interface) until I can get it working again to try 6.0).
For some reason, it does not look like it is trying to "ack" my TV which is 192.168.1.3.
If I have "bubblegumserver" on my LG Phone, it will recognize it. in the "Recognized Rednerders" (which of course don't want as a renderer, but a controller).
It will (sporadically) recognize Firefox (no consistency---can't figure out the why/why not), but it's because I assume that bump is installed.
Attached are debug logs (I turned on "Trace" only---not sure why it has other lines in there...apology if something I did wrong).
It also recognizes
"Server BOX"
X/Ubuntu.
It also recognizes
- (167 Bytes) Downloaded 446 times
Re: UMS just "stopped working"
It supposed to be trace and everything else, that's ok. But, there's nothing in the zipfile you've attached except "channel.log" with one line in it. We need "debug.log" when trace mode is on.
