Play-Fi support?
Klidec
Play-Fi support?
Post by Klidec »
I just purchased a new receiver. the Anthem MRX720. It supports Play-Fi which seems to be a competing standard to Airplay. There is an iPhone app you can download. it finds the receiver and treats it as a speaker that it can stream media to. In the app it can find media servers.
They recommend using these media servers:
https://play-fi.com/faq/entry/recommend ... r-software
https://play-fi.com/faq/entry/supported-media-servers
Would be great if we could add UMS to the mix.
I tried playing with the renderer conf files but I really don't know what i'm doing.
Supported Audio Formats:
https://play-fi.com/faq/entry/supported ... le-quality
FAQ:
Supported products/receivers/speakers:
http://listen.dts.com/pages/play-fi
Hope this is enough info.
I'd be happy to test a conf file.
thanks for the help!
