UMS Doesn't Recognize PS4
I'm new to all this, but I've installed the latest version of Java on my iMac (OS X 10.11.3), and set up UMS using the configuration wizard. UMS doesn't recognize my PS4, and I'm not sure what I'm doing wrong. Both the iMac and the PS4 are connected to the same WiFi network.
I've tried restarting the server, quitting and restarting the app, and I don't know what to do next. Can anyone help?
I've attached the debug files, though I'm not sure this is a "bug." I suspect I'm failing to do something?
- (13.93 KiB) Downloaded 494 times
Re: UMS Doesn't Recognize PS4
Hi, i had the same issue using my WIFI modem, i fixed the issue by directly connecting my iMac to the modem using ethernet cable, my PS4's media server was then able to see my iMacs media. Have noticed that if i have my iMacs VPN running it won't work either,
