Version 1.1.1 is released
General:
Changes since 1.1.0:
  • General:
    • Fixed memory buffer handling
    • Added LPCM transcoding option for all audio tracks
    • Added DTS HD-MA support up to 7.1 channels: DTS core remux, LPCM and AC3 transcoding
    • Added Dolby TrueHD support up to 7.1 channels: LPCM (recommended) and AC3 (buggy for 7.1) transcoding
    • Added support for more rare audio formats
    • Updated documentation in UMS.conf
  • Languages:
    • Improved English settings labels
    • Fixed spacing across all languages on the "Common transcode settings" page
    • Improved Russian translations
    • Removed outdated translations
    • Fixed display of maximum transcode buffer size in 5 languages (ca, es, is, it, sv)
    • Improved support for RTL languages
Upgrade Notes:
It is recommended to uninstall the older version before installing the new one.
Glebb for compiling the OS X version.
The PMS developers.
spida_singh
Re: Version 1.1.1 is released
Post by spida_singh »
Will this bitstream DTSHD-MA (not transcode to LPCM) to the PS3 now?
So the DTSHD-MA light will be lit on my receiver?
As well as Dolby Truehd?
If your receiver supports those formats it should do, yes
spida_singh
Wow!
Nice work. I will test some M2TS files from BD discs as well as MKV's.
Many Thanks :-D
spida_singh
Just tested this, when the LPCM lossless option is selected, it pipes the TrueHD or DTSHD-MA track as LPCM, mutli channel is lit up on the receiver, with 7.1 LPCM being reported on the PS3 info bar, with it unticked, it sends AC3 or DTS Core track instead as bitstream.
I'm guessing there is nothing available yet to pipe the bitstream (not LPCM transcoded) of a TrueHD and DTSHD-MA audio track to the PS3 yet?
spida_singh wrote:Just tested this, when the LPCM lossless option is selected, it pipes the TrueHD or DTSHD-MA track as LPCM, mutli channel is lit up on the receiver, with 7.1 LPCM being reported on the PS3 info bar, with it unticked, it sends AC3 or DTS Core track instead as bitstream.
The PS3 doesn't support those streams directly, but this process is lossless so it makes no difference. It's like when you listen to a FLAC file instead of an audio CD, technically the FLAC file is the result of transcoding but it still has all of the data of the CD so it hasn't lost any quality.
spida_singh
Thanks Sub. I thought so, it does sounds great, top work.
Regards
Sundeep
counsil
Post by counsil »
I have thoroughly regression tested this version (1.1.1) with at least 4 dozen mkv's I have created over the past few years. And believe me, I have created my mkv's over a dozen different ways, and with several different software programs, over the years. Other than some NPEs in the debug.log file (that don't seem to affect playback), this is a very stable build.
Great job SubJunk.
Cheers guys :)
DeFlanko
Contact:
Post by DeFlanko »
Counsil,
Any possibility of sharing those MKV files for stress testing?
