Version 2.4.1 is released
Post by SubJunk » Sat Feb 16, 2013 9:16 am
General:
This release adds support for Sharp Aquos TVs, 32-bit Linux, and RTMP support for FFmpeg which will allow plugins to become better!
Changes since 2.4.0:
  • General:
    • Improved autostart support
    Renderers:
    • Added support for Sharp Aquos TVs
    • Added support for Showtime 4
  • External Components:
    • Updated MPlayer/MEncoder for Windows and Linux to SB50, which:
      • Silences meaningless errors
      • Supports 32-bit Linux installations
    • Updated FFmpeg for Windows and Linux to SB7, which:
      • Adds RTMP support
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
Cameron Spiers for building the OS X version
kuroukage
Re: Version 2.4.1 is released
Post by kuroukage » Sat Feb 16, 2013 9:34 am
Will this version work with Jumpy (Automatic FFmpeg for subtitle support + Play nice with PMSE) without having to use Infidel's update.jar?
黒影
Post by SubJunk » Sat Feb 16, 2013 9:38 am
I doubt it since he has not submitted any code to us for that yet
kuroukage
Post by kuroukage » Sat Feb 16, 2013 9:43 am
Yeah I noticed he hasn't been around much lately. He been busy with something? Thanks for the heads up though. I'll wait until the next major version update to update again. Hopefully he'll submit his source code for the update.jar to you the next time he's around.
黒影
SuperDre
Post by SuperDre » Sat Feb 16, 2013 12:20 pm
It seems with the later releases the setting 'start automatically with windows' is set after you install the newer version even though I have turned it off (and saved it), maybe there are other settings which also keep resetting..
kuroukage
Post by kuroukage » Sat Feb 16, 2013 12:24 pm
I've noticed that too. I think it's because it adds it to your startup folder in the Windows start menu.
黒影
Post by SubJunk » Sat Feb 16, 2013 12:35 pm
Oh yeah, good point. I'll work on that
GaussTek
Post by GaussTek » Sun Feb 17, 2013 4:57 pm
Hey guys, I have an issue.
Since 2.4.0, my shared folders aren't detected on the XBOX 360, I can see an go into the Media server, but no folders/files.
Now, when I rollback to 2.3.0, it works just fine (I can see my shared folders and files and then play my videos). Wondering if someone else has this issue as well or if I'm doing something wrong.
The only config I apply everytime I install UMS are the Network Settings (network interface, server IP, port, etc.), and then I add my Media folders.
Of course, I've uninstalled/installed with "clean install".
Like I said, 2.3.0 works fine for now, but I had to uninstall the newest versions because they didn't work for me. Any idea on what's wrong? (sorry for my english BTW).
Thanks a lot! :P
Edit. Nope, it just doesn't work on 2.4.0/2.4.1. Tried again and applied EXACTLY the same config changes that I did when installing 2.3.0, and it just doesn't detect any of my folders :/ Rolled back yet again, applied the same config and worked fine on 2.3.0.
Post by SubJunk » Sun Feb 17, 2013 5:52 pm
Hi GaussTek, we're working on a fix :) Thanks for reporting it
