Youtube feeds no longer working.
inkrypted
Post by inkrypted »
I have a feed for Equals Three set up in my WEB.conf that I used to use with PS3 Media Server. and after switching to Universal Media Server that feed no longer works. I was using the pmsencoder plugin from Chocolateboy (Latest version) so I just moved the plugin into the UMS directory . As mentioned in another post i have installed youtube-dl When I attempt to play the stream I get and error that the content cannot be played back and the following errors in the log.
02-17 15:16:44  PMSEncoder: match error
org.codehaus.groovy.runtime.InvokerInvocationException: Assertion failed:
assert t != null
       | false
       null
	at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:97) ~[na:na]
	at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233) ~[na:na]
	at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:273) ~[na:na]
	at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:886) ~[na:na]
	at groovy.lang.Closure.call(Closure.java:282) ~[na:na]
	at groovy.lang.Closure.call(Closure.java:277) ~[na:na]
	at com.chocolatey.pmsencoder.Profile.runActionBlock(Profile.groovy:70) ~[na:na]
	at com.chocolatey.pmsencoder.Profile.match(Profile.groovy:114) ~[na:na]
	at com.chocolatey.pmsencoder.Matcher$match$3$1.doCall(Matcher.groovy:47) ~[na:na]
	at com.chocolatey.pmsencoder.Matcher$match$3$1.call(Matcher.groovy) ~[na:na]
	at groovypp.util.Iterations.each(Iterations.groovy:98) ~[na:na]
	at groovypp.util.Iterations.each(Iterations.groovy:154) ~[na:na]
	at com.chocolatey.pmsencoder.Matcher$match$3.doCall(Matcher.groovy:46) ~[na:na]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.7.0_09]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) ~[na:1.7.0_09]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.7.0_09]
	at java.lang.reflect.Method.invoke(Method.java:601) ~[na:1.7.0_09]
	at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90) ~[na:na]
	at groovy.lang.Closure.call(Closure.java:295) ~[na:na]
	at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:1220) ~[na:na]
	at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:1196) ~[na:na]
	at groovypp.util.Iterations.each(Iterations.groovy:280) ~[na:na]
	at com.chocolatey.pmsencoder.Matcher.match(Matcher.groovy:45) ~[na:na]
	at com.chocolatey.pmsencoder.Matcher.match(Matcher.groovy) ~[na:na]
	at com.chocolatey.pmsencoder.Plugin.match(Plugin.groovy:254) ~[na:na]
	at com.chocolatey.pmsencoder.PMSEncoder.launchTranscode(PMSEncoder.groovy:104) ~[na:na]
	at net.pms.dlna.DLNAResource.getInputStream(DLNAResource.java:1746) [ums.jar:2.4.2]
	at net.pms.network.Request.answer(Request.java:245) [ums.jar:2.4.2]
	at net.pms.network.RequestHandler.run(RequestHandler.java:246) [ums.jar:2.4.2]
	at java.lang.Thread.run(Thread.java:722) [na:1.7.0_09]
Caused by: org.mbte.groovypp.runtime.powerassert.PowerAssertionError: assert t != null
       | false
       null
	at com.chocolatey.pmsencoder.Action.youtube(Action.groovy:321) ~[na:na]
	at com.chocolatey.pmsencoder.Action.youtube(Action.groovy) ~[na:na]
	at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:362) ~[na:na]
	at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.callCurrent(PogoMetaClassSite.java:66) ~[na:na]
	at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallCurrent(CallSiteArray.java:44) ~[na:na]
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:141) ~[na:na]
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:145) ~[na:na]
	at youtube$_run_closure1_closure5_closure16.doCall(youtube.groovy:112) ~[na:na]
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:149) ~[na:na]
	at youtube$_run_closure1_closure5_closure16.doCall(youtube.groovy) ~[na:na]
	... 34 common frames omitted
02-17 15:16:55  There is no inputstream to return for HARLEM SHAKE VIDEOS
Also if I check use Mplayer for Thumbnails I get no thumbnails at all. I also noticed that UMS reports my Java version as Java: 1.7.0_09-Oracle Corporation In reality i am using.
java version "1.7.0_13"
Java(TM) SE Runtime Environment (build 1.7.0_13-b20)
Java HotSpot(TM) 64-Bit Server VM (build 23.7-b01, mixed mode)
As indicated by running java -version. I am using openSUSE 64 bit. Any help would be appreciated Thanks.
(4.01 KiB) Downloaded 661 times
R9deLima
Re: Youtube feeds no longer working.
Post by R9deLima »
I have Youtube feeds in my web.conf for the latest UMS and PMS and all have stopped working. I'm not sure when they stopped working, but I just noticed yesterday. Youtube must have changed something.
SharkHunter
Post by SharkHunter »
YouTube works via Channels. Try installing it and use youtube from there
R9deLima
Post by R9deLima »
Thanks SharkHunter! I've been using the youtube jumpy plugin and that works perfectly fine. I rarely use feeds in web.conf anymore. I was just curious as to why they stopped working. Jumpy and the channel plugin work well. Cheers!
kuroukage
Post by kuroukage »
@r9
Are you using the latest version of youtube-dl? They've been updating it a lot lately. All my feeds in web.conf for Youtube still work just fine. As well as in Jumpy and Channels.
黒影
R9deLima
Post by R9deLima »
Hi kuroukage,
The version of youtube-dl I have must be dated because I've never had to update it manually before. I thought it was pre-installed in UMS? Does it have to be downloaded to a specific location and do I need to add any command lines to UMS.conf? Thanks for your time.
SharkHunter
I haven't updated my youtube-dl for a while and since it works for me it should mast likely work for the rest....
kuroukage
Post by kuroukage »
SharkHunter wrote:I haven't updated my youtube-dl for a while and since it works for me it should mast likely work for the rest....
I've run into problems before where Youtube links stopped working and I had to download the latest youtube-dl so it would work properly again. Now I just figure might as well keep it up to date, so I don't have to worry about that again.
R9deLima wrote:Hi kuroukage,
You can put it anywhere as long as you have this line (or whatever directory you'd like at the bottom of your UMS.conf file):
youtube-dl.path = D:\\System\\bin\\youtube-dl.py
or
youtube-dl.path = D:\\System\\bin\\youtube-dl.exe
I'd recommend just grabbing the .exe version if you didn't install Python yourself.
If you're familiar with DOS you can just type youtube-dl --version to see which version you have. Then type youtube-dl --update to update it to the latest version. Or you can just manually download it from the link above.
黒影
R9deLima
Post by R9deLima »
SharkHunter and Koroukage, thanks again! My youtube web streams are rolling again. You guys are awesome. Keep up the great work!
kuroukage
Post by kuroukage »
@R9deLima
NP. Glad everything is working for you again. :)
黒影
