Small issue with 2.4.2 setup
orgon3
Post by orgon3 »
Looking at the attached JPEG, it seems that the text box was dragged a little too far down by accident. You can still make out what it says, so not the end of the world. It's only a little cosmetic issue. I figured I should bring it to your attention nonetheless. Thanks so much and keep up all the great work guys!!!!!!
Seems the text box was dragged down by accident. Just needs to be put back to where it belongs.
Optimus_prime
Re: Small issue with 2.4.2 setup
Post by Optimus_prime »
Good pick up,
Just checked myself and i have had the same issue.
Thanks for informing us
EDIT: I think subjunk has already commited the fix
https://github.com/UniversalMediaServer ... af0444a0a2
Should be in the next version, keep up the good work :D
orgon3
Post by orgon3 »
Optimus_prime wrote:Good pick up,
Thanks Prime!!! :D
kuroukage
Post by kuroukage »
Yeah I noticed this as well, but I figured SJ knew about it already (and would fix it in the next build), so I didn't mention anything. :P
黒影
