UMSBuilder 1.4 is released
General:
Lets Windows users build the latest revision of UMS for Windows and Linux.
Note: This will build the program from potentially untested code, so while it should usually be OK there are no guarantees.
If you want stability, download the latest official release from our front page.
You can download it here
Changes since 1.3:
  • Updated Java to 1.7.15
kuroukage
Re: UMSBuilder 1.4 is released
Post by kuroukage »
Thanks SJ,
Nice. I just upgraded to v7u15. I'll give this a try now since I noticed you changed it to make it build with JDK7. :)
Optimus_prime
Post by Optimus_prime »
Thanks Subjunk
kuroukage
Post by kuroukage »
I gave this a go last night and I must say I'm impressed by how easy this is and also how well it works. I love how u just click on the batch file and it ends up being a one click compiler. I wish I could find something as awesome/easy as this for more programs that I've been interested in compiling myself. :P
Yup I'm a big believer in keeping everything as simple as possible
kuroukage
Post by kuroukage »
Can you make one for RTMPDump, please? ;)
squadjot
Post by squadjot »
So if i run UMS builder.. i end up with a UMS-Linux.tgz, but i'm on windows ? =/
There's no UMS-Windows.exe
Extra question: Where can i find older versions of UMS
squadjot wrote:So if i run UMS builder.. i end up with a UMS-Linux.tgz, but i'm on windows ? =/
Is there an error? Maybe paste the CMD output into a new thread in the UMSBuilder section of the Support forum
squadjot wrote:Extra question: Where can i find older versions of UMS
Here
emutt
Post by emutt »
:geek: 1.4 Compiled fine..however, upon startup on windowz 7Pro I get java (?) error stating:
Could not find the main class:net.pms.PMS. Program will exit.
kuroukage
Post by kuroukage »
Odd, I compiled a build of 2.5.0 yesterday and it's working perfectly. I did do a fresh install though. BTW thanks SJ for using the latest Java now. I do notice a difference in speed. :)
