can I stop ums from transcoding avi files for xbmc?
chrismallia
Post by chrismallia »
I have Ums 2.5 installed on a server pc windows 8 x64 and a xbmc media center installed on a laptop running windows 8. the problem I am having is that ums is transcoding avi files for xbmc witch do not kneed transcoding, is there a way to stop transcoding for xbmc media center thans regards.
SharkHunter
Re: can I stop ums from transcoding avi files for xbmc?
Post by SharkHunter »
Update you XBMC.conf and set StreamExtension (or whatever it's called) = avi
chrismallia
Thanks for quick reply I am new to ums, Do you mind giving me the steps how to do it thanks again
SharkHunter
Look into the renders dir (found in your UMS install dir)
Find the file called XBMC.conf
Look for "StreamExtensions=..." and add avi to that list (,avi to end would do the trick)
and then save close restart UMS
chrismallia
Great thank you very much that did the trick, I had to put avi first in the list for some reason when it was last it did not work, it is now working perfect thanks
alfredbobes
Post by alfredbobes »
Actually there is one simple way to solve AVI won’t play on XBMC, which is to convert AVI to XBMC more compatible format like MP4, WMV. Here, a versatile AVI to XBMC converter-iDealshare VideoGo is highly recommended for its high efficiency and stability. Moreover, this user-friendly AVI to XBMC converter brings much convenience to users for its green environment and simple operation.
Step by step guide at http://www.idealshare.net/video-convert ... erter.html
