Which UMS.conf does UMS actually read?
PhilBeyondDriven
Post by PhilBeyondDriven »
I've got UMS installed, but regardless of which UMS.conf file I populate with my information, it seems a phantom version of it is what the system calls.
I'm trying to get my IP filter whitelist configured, but editing the UMS.conf entries from the following locations does nothing:
- home/user/.config/UMS/UMS.conf
- usr/local/ums-6.2.0/UMS.conf
- /etc/UMS.conf
I can have my WDTV and PS3's IP addresses in the whitelist, and only those IPs, and other clients (my laptop, g/f's laptop) still auto-connect because the system says no IP filter is configured. The way I've got the IP addresses listed:
# Use an IP filter (whitelist)
# Set the IP address(es) and/or IP address range(s) of the clients permitted
# to connect. When no filter is specified, UMS will allow any IP address to
# connect to the service.
# Multiple IP addresses and/or IP address ranges can be separated with a comma
# or semicolon e.g.: 127.0.0.1,192.168.0-1.*
# Default: ""
ip_filter =192.168.1.106,191.168.1.1.107
What am I doing wrong here?
valib
Re: Which UMS.conf does UMS actually read?
Post by valib »
I don't know what is the propper location of the UMS.conf on linux or OSx but you can change the UMS.conf directly from the UMS at the General Configuration table pushing the button "Edit UMS configuration manually".
newbietux
Contact:
Post by newbietux »
As I began to use universalmediaserver with linux (opensuse 13.0 to 13.2 in this time) and more than one user I would that UMS use the central stored /etc/UMS.conf file and the program and other files are stored below from /opt. There I have a symbolic link "UMS" to the actual ums folder.
From this time to today I changed a new UMS.sh and add only this 2 lines after the line 4 - and it works:
UMS_PROFILE="/etc/UMS/UMS.conf"
export UMS_PROFILE
With every new release I move the changed folder (as ex. "channels", "database" and so on) to the now actual programfolder and renew the link.
The start I've configured with the autostart function of the kde-desktop.
I hope that can help.
