TV LG 42LA660S
TV LG 42LA660S
Hello, I try also to do "go to" features on video files with my TV ;
UMS 6.2.2
the logs , if i understand well, the right configured renderer should fix the problem? if you have any other ideas please let me know!
the software is up to date on the TV
problem is Im not able to jump into the timeline (forward rewind / go to)
i try some options but with no effects (deactivate subtitles, chapter in TRANSCODE folder checked , ReMux if possible with TsMuxer)
Thanks!
UMS 6.2.2
Thanks!
- (1.25 MiB) Downloaded 460 times
Re: TV LG 42LA660S
I had no problem working the timeline back when I had my 55LA660S. I used the airmouse to move the slider anywhere I wanted and also the left/right directional buttons to skip 10 secs at a time. It worked every time. It definitely sounds like you have a configuration problem.
