[FIXED] 24-bit FLAC files weird "duplicate" streaming
Sami32
Post by Sami32 »
the FLAC music files have a weird displaying on my Panasonic Viera TX-L32E6E, with Windows XP SP3 32 bit, whatever Java version or UMS version, until 6.2.0, used.
The attachment PANASONIC_UMS.jpg is no longer available
So i don't know if a better renderer configuration file will do the trick but i din't find how to display this kind of file as one file only. It's look like it affect only 24 bit FLAC files streaming.
The FLAC second part (write as Music and not the wrong MPEG2-PS) are playing fine without transcoding though.
In an USB key plug on my TV everything is fine.
The attachment recit24bit.zip is no longer available
(115.14 KiB) Downloaded 410 times
Thank you to @subjunk for this fix :-)
