A couple qustions about live subtitles
jhr1948
Post by jhr1948 »
Hi, I love your work. I was curious about the new live subtitles feature:
First, I tend to believe in transcoding first and encoding second. I'm no expert on this so hang with me here. Does the new live subtitles feature require encoding like mencoder does?
Second, When i tested it out, mind you i was just quickly testing it out, the subs were not in time at all. Is there something in UMS I failed to set that would've fixed that?
jhr1948
Re: A couple qustions about live subtitles
Post by jhr1948 »
forget the 2nd thing, everything seems fine now.
Still wondering if there's encoding or transcoding going on. Just curious.
SharkHunter
Post by SharkHunter »
The subtitles behave just as external subtitles does. Either mencoder/ffmpeg is used to add them to the stream but if the video stream is transcoded or not is based on the video format.
jhr1948
Post by jhr1948 »
thanks sharkhunter.
Just want to make sure I do get this straight. If the mkv file is able to be remuxed by tsmuxer (no transcoding), live subtitles wont transcode with the video stream?
Sorry if its a dumb question, still learning all the terminology and functions.
thanks
squadjot
Post by squadjot »
jhr1948 wrote:thanks sharkhunter.
thanks
I woundt call it functionality.. rather lack of same, or even buggy.
Subtitles since 2.2.0 just needs to be fixed, end of story. Sorry, this issue is getting old.
AFAIK whatever you select in the Live Subtitles folder will always play
