UMS Disconnects from PS4 after exactly 19m45s
Nelsormensch
Post by Nelsormensch »
Prior to yesterday, I was able to stream from my PC to my PS4 with UMS without any trouble at all. Then my main HD died yesterday and I had to reinstall Windows10.
After reinstalling everything, UMS now stops streaming to my PS4 exactly 19 minutes and 45 seconds after streaming was started. Tried with several different files, all stopped at exactly 19m45s. I was using my PC while the streaming was going on, so it wasn't some sleep setting on my PC.
There isn't an error, the PS4 just dumps back to the main Media Player screen without UMS visible any longer. I need to close and reopen Media Player for UMS to be detected again.
Attached .zip with logged Trace, hopefully that's of use.
Latest PS4 firmware
UMS 6.3.1.1 (build date: 2016-05-22)
Java V8 Update 25 (build 1.8.0_25-b18)
19m45s_Disconnect.zip
(61.02 KiB) Downloaded 475 times
Nelsormensch
Re: UMS Disconnects from PS4 after exactly 19m45s
I uninstalled and rolled back to UMS 6.3.0 (without making any other changes) and everything is seemingly working fine again. Maybe this is a bug in the latest? Happy to test anything if that's of use, otherwise it seems I'm good on 6.3.0.
erick diangilis
Post by erick diangilis »
i ve had this problem too because of this i rolled back to 6.3.0 its working fine for me and i also noticed some quality degradation on the stream of audio and sound on these new versions as well my tv is callibrated so is very easy to notice any changes to good or bad quality.
ps4 with update 3.50
Windows 10 with java 8.91
Nitsuj
Post by Nitsuj »
same for me
I also posted in this thread : viewtopic.php?f=9&t=7999
here is a log:
TRACE 2016-05-25 22:15:44.320 [ffmpeg.exe-17-Timer] buffered: 208 028 083 bytes / inputs: 1
DEBUG 2016-05-25 22:15:44.560 [ffmpeg.exe-17-2] frame=43949 fps= 38 q=18.0 size= 595482kB time=00:30:33.37 bitrate=2660.8kbits/s speed=1.57x
DEBUG 2016-05-25 22:15:45.568 [ffmpeg.exe-17-2] frame=43991 fps= 38 q=14.0 size= 595985kB time=00:30:35.19 bitrate=2660.4kbits/s speed=1.57x
TRACE 2016-05-25 22:15:46.320 [ffmpeg.exe-17-Timer] buffered: 207 913 683 bytes / inputs: 1
TRACE 2016-05-25 22:15:46.750 [New I/O worker #2] Ready to Stop: true
TRACE 2016-05-25 22:15:48.320 [ffmpeg.exe-17-Timer] buffered: 609 256 148 bytes / inputs: 0
DEBUG 2016-05-25 22:15:49.253 [ffmpeg.exe-17-Cleanup] Stopping process: ffmpeg.exe-17
TRACE 2016-05-25 22:15:49.253 [ffmpeg.exe-17-Cleanup] Destroying buffer
DEBUG 2016-05-25 22:15:49.263 [Thread-97] Error: null
TRACE 2016-05-25 22:15:50.270 [ffmpeg.exe-17] EOF
DEBUG 2016-05-25 22:15:50.753 [StopPlaying Event] Matched media renderer "PlayStation 4" based on address /192.168.1.18
TRACE 2016-05-25 22:15:51.170 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.35:57299]
INFO 2016-05-25 22:15:51.303 [StopPlaying Event] Stopped playing xxx.mkv on your PlayStation 4
DEBUG 2016-05-25 22:15:51.303 [StopPlaying Event] The full filename of which is: C:\...\xxx.mkv and the address of the renderer is: 192.168.1.18
DEBUG 2016-05-25 22:15:51.303 [StopPlaying Event] Resume stop. This segment 1169829 new time 1169829
TRACE 2016-05-25 22:15:51.310 [StopPlaying Event] Fully Played feature logging:
TRACE 2016-05-25 22:15:51.310 [StopPlaying Event] duration: 2488.0
TRACE 2016-05-25 22:15:51.310 [StopPlaying Event] getLastStartPosition: 0.0
TRACE 2016-05-25 22:15:51.310 [StopPlaying Event] getStartTime: 1464206181474
TRACE 2016-05-25 22:15:51.310 [StopPlaying Event] getLastStartSystemTime: 1.464206178409E12
TRACE 2016-05-25 22:15:51.310 [StopPlaying Event] elapsed: 1169.0
TRACE 2016-05-25 22:15:51.310 [StopPlaying Event] minimum play time needed: 2288.96
TRACE 2016-05-25 22:15:51.310 [StopPlaying Event] final decision: not fully played
DEBUG 2016-05-25 22:15:51.310 [StopPlaying Event] adding "xxx {Sous-titre :SubRip}" to playlist "Joué récemment"
TRACE 2016-05-25 22:15:54.950 [UPNPHelper] Receiving a NOTIFY from [192.168.1.254:1900]
TRACE 2016-05-25 22:15:57.170 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.35:57299]
DEBUG 2016-05-25 22:16:02.980 [UPNP-AliveMessageSender] Sending ALIVE...
TRACE 2016-05-25 22:16:02.983 [UPNPHelper] Receiving a NOTIFY from [192.168.1.35:55343]
Hey guys, please try this version and let me know if it fixes this issue:
http://www.universalmediaserver.com/upl ... e85dbc.exe
