Always transcode DTS
I am new to UMS.
I would like to know how to always transcode DTS because my renderer does not support it.
Thanks per advance for your help.
P.S. : Excuse me if my english is not good, I am french
I am new to UMS.
Re: Always transcode DTS
hi go to the transcoding options and select audio adjustment unmark the ac3 option and mark the dts one this should do the trick if you have playback problems go back to ac3 by default i have a hometheater so i Always use the dts options.
i hope it helps have a good day.
