No renderers were found (Still this problem)
erwina
Post by erwina »
Hi all,
plz i need help, I prefer create a new topic because I speak little English and find solution is difficult.
The message "No renderers were found" appeared after an update of Java.
I installed again UMS,Java and reboot several times.
it is to have my movies on my tv.
Adress IP :
- my computer with server : 192.168.1.10
- my tv : 192.168.1.50
- my box 192.168.1.1
all with IP fix
------- thx for your help
INFO  2013-04-11 01:27:38.603 [main] UMS will start automatically with Windows
INFO  2013-04-11 01:27:38.821 [main] Starting Universal Media Server 2.6.0
INFO  2013-04-11 01:27:38.837 [main] Based on PS3 Media Server by shagrath, copyright 2008-2013
INFO  2013-04-11 01:27:38.837 [main] http://www.universalmediaserver.com
INFO  2013-04-11 01:27:38.837 [main] Build: b0d3daba1 (2013-03-29)
INFO  2013-04-11 01:27:38.837 [main] Java: 1.7.0_17-Oracle Corporation
INFO  2013-04-11 01:27:38.837 [main] OS: Windows 7 64-bit 6.1
INFO  2013-04-11 01:27:38.837 [main] Encoding: UTF-8
INFO  2013-04-11 01:27:38.837 [main] Memory: 742 Mo
INFO  2013-04-11 01:27:38.837 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2013-04-11 01:27:38.837 [main] Temp directory: C:\Users\Chris\AppData\Local\Temp\universalmediaserver
INFO  2013-04-11 01:27:38.837 [main] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2013-04-11 01:27:38.853 [main] debug.log: C:\Program Files (x86)\Universal Media Server\debug.log
INFO  2013-04-11 01:27:38.853 [main] Profile directory: C:\ProgramData\UMS
INFO  2013-04-11 01:27:38.853 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2013-04-11 01:27:38.853 [main] Profile permissions: rw
INFO  2013-04-11 01:27:38.853 [main] Profile name: Chris-PC
INFO  2013-04-11 01:27:38.853 [main] Loading MediaInfo library
INFO  2013-04-11 01:27:38.899 [main] Loaded MediaInfoLib - v0.7.62
INFO  2013-04-11 01:27:38.899 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO  2013-04-11 01:27:38.899 [main] Loading configuration file: AirPlayer.conf
INFO  2013-04-11 01:27:38.915 [main] Loading configuration file: Android.conf
INFO  2013-04-11 01:27:38.915 [main] Loading configuration file: BlackBerryPlayBook-KalemSoftMP.conf
INFO  2013-04-11 01:27:38.915 [main] Loading configuration file: Bravia4500.conf
INFO  2013-04-11 01:27:38.915 [main] Loading configuration file: Bravia5500.conf
INFO  2013-04-11 01:27:38.915 [main] Loading configuration file: BraviaEX.conf
INFO  2013-04-11 01:27:38.915 [main] Loading configuration file: BraviaEX620.conf
INFO  2013-04-11 01:27:38.915 [main] Loading configuration file: BraviaHX.conf
INFO  2013-04-11 01:27:38.915 [main] Loading configuration file: DirecTVHR.conf
INFO  2013-04-11 01:27:38.915 [main] Loading configuration file: DLinkDSM510.conf
INFO  2013-04-11 01:27:38.915 [main] Loading configuration file: FreeboxHD.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: FreecomMusicPal.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: iPad-iPhone.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: Kuro.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: LGST600.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: N900.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: NetgearNeoTV.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: OnkyoTX-NR717.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: OPPOBDP83.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: OPPOBDP93.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: Panasonic.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: Philips.conf
INFO  2013-04-11 01:27:38.931 [main] Loading configuration file: PhilipsPFL.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: PopcornHour.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: PS3.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: Realtek.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: SamsungAllShare.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: SamsungWiseLink.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: SharpAquos.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: Showtime3.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: Showtime4.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: SMP-N100.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: SonyBluray.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: SonyHomeTheatreSystem.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: Streamium.conf
INFO  2013-04-11 01:27:38.946 [main] Loading configuration file: TelstraTbox.conf
INFO  2013-04-11 01:27:38.962 [main] Loading configuration file: VideoWebTV.conf
INFO  2013-04-11 01:27:38.962 [main] Loading configuration file: VizioSmartTV.conf
INFO  2013-04-11 01:27:38.962 [main] Loading configuration file: WDTVLive.conf
INFO  2013-04-11 01:27:38.962 [main] Loading configuration file: WMP.conf
INFO  2013-04-11 01:27:38.962 [main] Loading configuration file: XBMC.conf
INFO  2013-04-11 01:27:38.962 [main] Loading configuration file: XBOX360.conf
INFO  2013-04-11 01:27:38.962 [main] Loading configuration file: YamahaRXA1010.conf
INFO  2013-04-11 01:27:38.962 [main] Loading configuration file: YamahaRXV3900.conf
INFO  2013-04-11 01:27:38.962 [main] Loading configuration file: YamahaRXV671.conf
INFO  2013-04-11 01:27:38.962 [main] Please wait while we check the MPlayer font cache, this can take a minute or so.
DEBUG 2013-04-11 01:27:38.962 [main] Launching: win32/mplayer.exe
DEBUG 2013-04-11 01:27:39.056 [main] Launching: win32/mplayer.exe
INFO  2013-04-11 01:27:39.151 [main] Finished checking the MPlayer font cache.
DEBUG 2013-04-11 01:27:39.151 [main] AviSynth plugins directory: C:\Program Files (x86)\AviSynth\plugins
INFO  2013-04-11 01:27:39.151 [main] VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
INFO  2013-04-11 01:27:39.151 [main] Found VideoLAN version 2.0.5 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2013-04-11 01:27:39.167 [main] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2013-04-11 01:27:39.167 [main] No plugins found
INFO  2013-04-11 01:27:39.182 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2013-04-11 01:27:39.182 [main] Registering transcoding engine: FFmpeg Audio
INFO  2013-04-11 01:27:39.182 [main] Registering transcoding engine: MEncoder
INFO  2013-04-11 01:27:39.182 [main] Registering transcoding engine: AviSynth/MEncoder
INFO  2013-04-11 01:27:39.182 [main] Registering transcoding engine: MPlayer Audio
DEBUG 2013-04-11 01:27:39.198 [main] FFmpeg supported protocols: [applehttp, bluray, cache, concat, crypto, data, file, gopher, hls, http, httpproxy, mmsh, mmst, pipe, rtp, srtp, tcp, udp, rtmp, rtmpe, rtmps, rtmpt, rtmpte, mms, https]
INFO  2013-04-11 01:27:39.213 [main] Registering transcoding engine: FFmpeg Web Video
INFO  2013-04-11 01:27:39.213 [main] Registering transcoding engine: MEncoder Web
INFO  2013-04-11 01:27:39.213 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2013-04-11 01:27:39.213 [main] Registering transcoding engine: MPlayer Web
INFO  2013-04-11 01:27:39.213 [main] Registering transcoding engine: tsMuxeR
INFO  2013-04-11 01:27:39.213 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2013-04-11 01:27:39.213 [main] Found VLC version 2.0.5 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2013-04-11 01:27:39.213 [main] Registering transcoding engine: VLC Audio Streaming
INFO  2013-04-11 01:27:39.213 [main] Registering transcoding engine: VLC Video Streaming
INFO  2013-04-11 01:27:39.213 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2013-04-11 01:27:39.213 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2013-04-11 01:27:39.260 [main] Using address /192.168.1.10 found on network interface: name:eth3 (Realtek PCIe GBE Family Controller)
INFO  2013-04-11 01:27:39.260 [main] Created socket: /192.168.1.10:5001
DEBUG 2013-04-11 01:27:39.369 [main] Sending ALIVE...
INFO  2013-04-11 01:27:39.385 [main] Using the following UUID configured in UMS.conf: 5b1d4b64-dff5-4586-b14c-612b072b9ab9
INFO  2013-04-11 01:27:39.650 [main] The server is now available for renderers to find
DEBUG 2013-04-11 01:27:49.651 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2013-04-11 01:28:02.739 [UPNPHelper] No IP filter specified, access granted to /192.168.1.12
DEBUG 2013-04-11 01:28:09.697 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-04-11 01:31:09.718 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2013-04-11 01:32:54.644 [UPNPHelper] No IP filter specified, access granted to /192.168.1.10
DEBUG 2013-04-11 01:34:09.758 [UPNP-AliveMessageSender] Sending ALIVE...
