Stream YouTube in FullHD to LG bd-660 from Windows XP
golddesign
Post by golddesign »
I have tried for a last 3 hours after installing the software simply to launch the youtube in full HD and nothing seems to work. Went via searches, FAQ, was on that page - viewtopic.php?f=9&t=356 . I didn't change the UMS.conf but I added chanles.YouTube=XXX,XXX to UMS.cred.
I recently got an LG player and it has only SD but want to stream FULL HD. I installed the software, installed the chanells plugin from software. Downloaded youtube chanel to the folder - it is visible on plazma tv but nothing plays from it. All main functions aka playing movies from PC or playing TED from Web folder do work.
Can you please explain or just post a link where I can find what is required to change/download.
Thanks in advance
