[] Images transcoding ?
Sanselan, TwelveMonkeys, Metadata-extractor or FFMpeg can do the job, but i'm not skilled to know which one will use less CPU and less memory for that purpose.
will do the job.
Or this sample of code taken on the Web :
But, if anyone was interested, some more metadatas will need to be extracted to get a more precise, correct renderer's configuration ( CMYK and Progressive attribute write in the supported formats ).
DLNAMediaInfo.java could need some getImageInfo adds like : and ?
Just some ideas that i got when i was reading some posts on this forum
EDIT : On his way..., thank very much to @Valib
https://github.com/UniversalMediaServer ... r/pull/911
https://github.com/UniversalMediaServer ... issues/886
import java.awt.Graphics2D;
import java.awt.image.BufferedImage;
import java.io.File;
import javax.imageio.ImageIO;
public class Tiff2JpgTest {
public static void main(String args[])
try
BufferedImage image = ImageIO.read(new File("test.tiff"));
image = convert(image, BufferedImage.TYPE_INT_RGB);
ImageIO.write(image, "jpg", new File("test.jpg"));
System.out.println("done.");
catch(Exception e)
e.printStackTrace();
public static BufferedImage convert(BufferedImage src, int bufImgType) {
BufferedImage img= new BufferedImage(src.getWidth(), src.getHeight(), bufImgType);
Graphics2D g2d= img.createGraphics();
g2d.drawImage(src, 0, 0, null);
g2d.dispose();
return img;
isProgressive()
getColorType()
