Version 2.6.1 is released
General:
This release fixes several bugs, improves speed, improves compatibility with some renderers and more!
Changes since 2.6.0:
  • General:
    • Added option to toggle H.264 remuxing in FFmpeg
    • Improved stability of Live Subtitles
    • Re-enabled WMP detection
    • Speed improvements
    • Fixed transcoding to Xbox via FFmpeg
    • Added support for WTV files
    • A-to-Z virtual folders support sorting options
    • Fixed a crash with rare MP3 files
  • Renderers:
    • Improved Sony Blu-ray Player support (thanks, skeptical and Ranger187!)
    • Fixed exception on Android
    • Fixed stuttering issues with Bravia HX TVs
  • Languages:
    • Updated Dutch translation (thanks, leroy!)
    • Updated Italian language (thanks, nocciola82!)
  • External Components:
    • Updated FFmpeg for Linux to burek's 2013-04-04 build, which:
      • Is compiled statically
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
It is recommended (but usually not necessary) to delete your UMS.conf file prior to installing this version. For Windows users you can choose the "clean install" option while installing instead.
Optimus_prime
Re: Version 2.6.1 is released
Post by Optimus_prime »
OS-X Build is up on Sourceforge
Phonism
Post by Phonism »
Thank you for 2.6.1! Upgraded from 2.6.0 with clean install, and it's working flawlessly :D
UMS 5.3.0 - Java 8 update 60 - Windows 10 Pro 64bit
Intel Core i7-3770 - 8GB RAM
PS3 Slim 120GB
PS4
jhr1948
Post by jhr1948 »
hi and thanks for the update!!!
can you help me understand what the added option of toggling h.264 remixing in FFmpeg is? and maybe if that would be more beneficial in my situation?
I currently have tsmuxer do my remixing since i'm trying not to transcode my files.
In 2.5.0 we gave FFmpeg the ability to mux videos, and this allows you to enable/disable that :)
Ranger187
Contact:
Post by Ranger187 »
Don't you mean thanks Ranger187 as well for the Sony conf updates?
viewtopic.php?f=9&t=719
Yup, sorry for forgetting your credit, I added it now
Ranger187
Contact:
Post by Ranger187 »
SubJunk wrote:Yup, sorry for forgetting your credit, I added it now
It's all good. I saw the newer conf for the Sony Bluray...
It's mint! Glad you separated the models at the bottom.
What we need next is an IOS and Android app that can remotely talk/manage UMS....
PS: I love UMS. ;)
