UMS.code is not working
mloyola
Post by mloyola »
First and foremost I have to say Universal Media Server Is Amazing, I love it for so many different reasons and would love to take part in any beta testing.
However I have run into a problem of my own that I cannot wrap my head around.
OS: Windows 10 64 Bit
Universal Media Server 6.3.2
After creating the UMS.code file with the following code and placed in the UMS folder located in C:\ProgramData\UMS nothing happens ? should the folder be a parent folder, sub folder ?
.*private.*,1234
the wiki below looks promising however perhaps I'm looking in the wrong location for UMS
https://github.com/UniversalMediaServer ... d-Security
I ran into another forum where a gentlemen identifies the code above as a bug and corrects it with the following, however this does not work either
.*__private__.*,1234
any help is greatly appreciated
kind regards,
mloyola
Re: UMS.code is not working
Post by mloyola »
attached is my UMS.code file. Logs are useless at this point since there is no error or sign of the file even being recognized.
UMS.zip
UMS.code
(135 Bytes) Downloaded 798 times
mloyola
Post by mloyola »
I got it to work for the record.
the correct expression is exactly as mentioned the url below .*Private.*,12345
however this only worked after completely exiting UMS and re launching UMS
hope this helps anyone having the same troubles I did :)
UMS ROCKS!! :D
