No Fast Forward or Rewind ONLY with videos H265 - UMS 6.4.0
Bakala
Post by Bakala »
Greetings, I have a LG TV 47LM860V not compatible with H265, but thanks to the UMS version 6.4.0 I can play videos with this codec. However I can not use the functions of rewind and fast forward (but only occurs with H265 videos, with everyone else it does allow me). I wanted to know if there is any option to configure the program or wait for a new version of UMS to use the functions of rewind and fast forward.
Details:
-Cable Ethernet, both PC and TV.
-PC: Windows 10 PRO, I5-6500 * 16GB DDR4 RAM * Asus Z170 Pro Gamer
Regards.
Madoka
Re: No Fast Forward or Rewind ONLY with videos H265 - UMS 6.4.0
Post by Madoka »
You didn't post your debug logs, and I don't have your TV.
But, if your TV is not compatible with h265, then UMS is transcoding the video over. Some renders do not allow FF/RW with transcoded videos. The PS4 had this issue until they recently updated their media player. If this is the case, then no update to UMS will fix this. The TV manufacturer needs to fix it like how Sony did with the PS4.
Bakala
Post by Bakala »
Hi Madoka, thanks for your help, I will test it.
Greetings
